Donate Now Goal amount for this year: 3000 USD, Received: 2340 USD (78%)
Results 1 to 4 of 4
Thread: Section head workaround not working in 2017?
    Member DavidLarson's Avatar
    July 10, 2015
    Boise, Idaho
    351
    03:32 AM
    The old workaround of using text in the section head callout to make the line isn't working anymore. I had families going back to 2012 that worked fine but when they're used in 2017 the text is offset far to the left.
    Is this workaround still viable? More importantly, why does Autodesk refuse to give us a section head tool that works right?
    Attached Thumbnails Attached Thumbnails Section head workaround not working in 2017?-screenshot-2016-10-13-08.30.11.png
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    03:32 AM
    Does this have something to do with the text editor improvements from past versions to 2017?
    July 10, 2015
    Boise, Idaho
    351
    03:32 AM
    That's what I'm thinking. I'd like to know if there is a solution instead of a workaround to a workaround
    8,848
    04:32 AM
    Confirming: The fix for this is going in the view heads, and COMPLETELY recreating the "text underlines," from native 2017 text. Meaning delete the ones that were present before, and create them from the new text tool. Seems to be working over here.
    So far no other solution, just the workaround. But at least its fixable.
  1. Section head and section line control
    By jpeter78 in forum Architecture - Family Creation
    Last Post: January 22nd, 2016, 04:56 PM
  2. Section Head
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: January 11th, 2016, 04:40 PM
  3. Section Head family
    By simon1688 in forum Architecture - Family Creation
    Last Post: November 23rd, 2015, 03:37 PM
  4. Section Head Color
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 04:17 AM
  5. Section Head as Elevation
    Last Post: January 18th, 2011, 05:53 PM
