Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By ekkonap
  • 1 Post By GMcDowellJr
Thread: Mapping Parameters in Bulk
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,555
    02:41 PM
    Is there any way to map parameters from a nested family to the host family programmatically? I'm updating a bunch of families and am remapping the same 4 parameters in every single one of my families and it's mind numbing. Something like the replace parameter function in CTC BIM Suite or Spectrum would be awesome.
    December 21, 2010
    C.LONDON
    3,922
    07:41 PM
    I had to do this today.
    I too would be interested to know if "there's an app for that!" as I'm getting ever closer to throwing down a purchase order to make these tasks less painful.
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    551
    08:41 PM
    did you try matching the old and new nested family names before loading the new one in, and taking care not to rename the parameters?
    Also, instance parameters with identical names will retain their association if you switch the family type, manually or by family Type parameter. For projects you'd need a shared parameter, in families any parameter will do.
    If the parameter set that needs to be associated is stable between versions, you could try coding all the parameter values into one number value in one parameter in the host family, and decoding it in the nested families. Bit technical, and rather useless if the above works for you, or if you need text or materials.
    JWR likes this.
    September 19, 2015
    147
    08:41 PM
    Hi Ekko,
    This sounds interesting. Could you please provide us with some explanations or a link?
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    02:41 PM
    I thought Maller (twiceroadsfool) had some workflow that allowed for this. Let me do a quick search and see if I can find it.
    August 9, 2011
    Louisville, KY
    5,555
    02:41 PM
    Quote Originally Posted by ekkonap View Post
    I did a lot of renaming of parameters and families Just something to watch out for next time
    8,478
    01:41 PM
    Quote Originally Posted by rbcameron1 View Post
    Not for MAPPING the parameters of the nesteds to the parameters of the host, when you have renamed the PARAMETERS in the Nesteds.
    Chad and i talked about it at length last week. Its the one part that is still excruciatingly manual.
    December 21, 2010
    Phoenix, AZ
    2,101
    12:41 PM
    Looks like that is exposed in the API... should be possible right code to manage the process. Anybody good with Python or VB?
    ParameterMap Members
    Yna_Db likes this.
    May 23, 2011
    Netherlands
    551
    08:41 PM
    Quote Originally Posted by Yna_Db View Post
    Hi Ekko,
    the basic principle is very simple. Say you have two integer parameters that can vary between 0 and 9. You can multiply one of them by 10 and add that to the other one with a formula in a third parameter. You can associate that parameter to onr in a nested family. There you divide by 10 and round down the combined value, giving you the first integer. Multiply by 10 and subtract it from the combined value gives you the second value.
    the need to restrict the range is a hassle, this method is best used for bool values translated to binary and then to decimals. I plan to do a writeup this summer fot use at RTC europe.
    September 19, 2015
    147
    08:41 PM
    Hi everyone,
    For those who would be interested in a simple solution with Dynamo, I tried to find the beginning of an appropriate script before I go for a short vacation, and here is the result. Basically, I put an instance of the family with one of the nested element in the same Revit file, so that I can select them simultaneously. The parameters to be modified have to be instance parameters, otherwise they won't appear in the list. What is still strange is that the index numbers keep changing each time I run the script, but for a one-time use, it seems to do the job. This can surely be improved for more complex situations. Any reaction welcome, I'll post this in a Dynamo forum next week if needed.
    Ekko, thanks for the answer, I'll try that next week...
  1. Mapping Revit parameters to IFC parameters
    By tuekappel in forum Architecture and General Revit Questions
    Last Post: January 31st, 2016, 09:33 PM
  2. Replies: 0
    Last Post: August 28th, 2015, 11:45 AM
  3. Adding views to sheets in bulk?
    Last Post: May 7th, 2014, 08:18 PM
  4. Copy shared paramters in bulk
    By cellophane in forum Architecture - Family Creation
    Last Post: June 26th, 2012, 04:27 AM
  5. text font or parameters bulk conversion
    By biff in forum Architecture and General Revit Questions
    Last Post: December 6th, 2011, 11:17 PM
