Results 1 to 4 of 4
Thread: Spot Elevation Family
    Member Elisa's Avatar
    December 8, 2010
    Los Angeles, CA USA
    65
    08:50 AM
    Exclamation Spot Elevation Family
    I attached an image of what I want to and where I think I should be able to.
    In the Symbol parameter, default is (none) but where do I set it to something? I can't figure out how. I think that is where I should be placing my datum symbol.
    Thanks!
    Kingdom of Denmark
    4,225
    05:50 PM
    What template have you been using ? Are you positive that a Spot Elevation Annotation Symbol is loaded ito the project ?
    (Look for it in Project Browser > Families > Annotations)
    Otherwise, you could try to post your .rvt file (Make a copy and delete/purge everything not needed)
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    11:50 AM
    It should be there, did you purge the "target filled" family by any chance? it should be under Annotations - Spot Elevation Target filled w/ extensions
    December 8, 2010
    Los Angeles, CA USA
    65
    08:50 AM
    Very weird, the image I showed has the spot elevation tag, but in my families I can't find the Spot Elevation family! And yes I think I did purge the "target filled" family. I figured I could chose the Level Head symbol.
    So I'm confused how is it that I am able to place the "Spot Elevation" and not have the family loaded?
    Edit: I see what it is, the Spot Elevation families are the symbols, the Tag (as I've called it) is a System Family, it won't be listed. Sorry I had a brain freeze! But thank you I see now what I need to do. Thanks for you help!!!
  1. Spot Elevation in Drafting View
    Last Post: January 22nd, 2017, 11:07 PM
  2. Ramp spot elevation
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2011, 08:44 PM
  3. Site elevation vs. Shared Elevation
    By KimArndt in forum Architecture and General Revit Questions
    Last Post: March 28th, 2011, 01:24 PM
  4. Spot Elevation Family - many applications
    By Alex Cunningham in forum Structure - Family Creation
    Last Post: December 14th, 2010, 02:30 PM
