Results 1 to 3 of 3
Thread: Custom Call Out Head with Variables
    February 11, 2016
    Cincinnati, OH
    13
    03:01 AM
    So, round 2 of pain and punishment begins with modifying my call out heads to our company standard.
    I'm attaching a screen shot of the options that I want embedded into the call out head, much like my previous thread on custom section heads with variables. I've created the family with very similar visibility parameters as the section head, but when I bring the call out head into the project, I'm not given the same drop down list in the properties family selector when I create a call out to choose which family with which visibility I want. I find this strange because with the section heads, I can click the section head and all the families are available for choosing. Not so with the call out head.
    Basically, I need a section head to have a sheet reference label and a visibility parameter attached to it, and I need a straight string of text that says "THIS DWG." with a visibility parameter attached to it for a callout with a detail on the same dwg. Then, the similar ability as the custom section heads to choose the family I need based upon where the detail callout is located (left or right hand orientation, referencing sheet or same sheet).
    Here are the screen shots, and I'll attach the call out head families to see if anyone has any suggestions.
    Thanks for the help.
    Attached Thumbnails Attached Thumbnails Custom Call Out Head with Variables-detail-call-out-head-left-orientation-2.png   Custom Call Out Head with Variables-detail-call-out-head-left-orientation.png
    Attached Files Attached Files
    February 11, 2016
    Cincinnati, OH
    13
    03:01 AM
    Problem solved. Thanks for reading.
    New Member corinoco's Avatar
    February 6, 2012
    Sydney, Australia
    1
    05:01 PM
    Quote Originally Posted by Justso View Post
    Thats fantastic! Would you mind sharing your solution?
  1. Custom Section Head with Variables
    By Justso in forum Architecture - Family Creation
    Last Post: February 16th, 2016, 06:48 PM
  2. Variables in Offset Property
    By CRapai in forum MEP - General
    Last Post: May 15th, 2015, 08:38 PM
  3. Call-Out Head Rotated 90 for some reason ... halp?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: November 20th, 2013, 09:36 PM
  4. Custom Callout Head Tag missing middle line
    By nikkiyoung in forum Architecture - Family Creation
    Last Post: August 8th, 2012, 12:16 AM
