Results 1 to 2 of 2
Thread: Amending speciality equipment project units
    January 21, 2016
    1
    05:34 AM
    My work involves working with families of speciality equipment - usually unavailable in the UK where I'm based, which pushes me to use families created elsewhere around the world.
    I have a large number of .rfa files created in the U.S. which are in imperial when I open them up. Although I know bringing them into a metric project removes this issue, what I really need to be able to do is have the ability to bring these files into a project, Edit Family, then Reload after amending the family slightly. At the moment, when I bring imperial families into a metric project, they show imperial again when being edited from the project.
    Without individually changing the project units from each .rfa before using them in a project, is there a way to do this? I tried the following: Automating the conversion of imperial files to metric | REVIT.AU ...but it doesn't seem to have any effect on the file when I re-open. Still metric.
    Ideas appreciated.
    Thanks!
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,119
    01:34 AM
    Try renaming the family in the project and loading in the new modified family with the original name, then doing a select-all and change the type to the new modified family.
    Equipment-1
    Right-Click / Rename: Equipment-1a
    Load modified family: Equipment-1
    Right-Click on Equipment-1a, Select All Instances in Project
    In the Type Selector change it to the modified family Equipment-1
  1. Project Units
    By Lox in forum Architecture and General Revit Questions
    Last Post: September 7th, 2014, 09:25 PM
  2. Setting a Parameters Value and Project Units
    By samz1 in forum Third party Add-Ins, API and R&D
    Last Post: May 9th, 2014, 05:55 AM
  3. How i can make the family with default project units ?
    Last Post: September 30th, 2011, 01:00 PM
  4. Speciality Equipments families missing in Revit MEP 2011
    By prawin92 in forum MEP - Family Creation
    Last Post: August 11th, 2011, 12:00 PM
  5. Specialty Equipment - Project or Shared Parameters
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 01:51 PM
