Results 1 to 4 of 4
Thread: Nested Family Location Shifting When Changing Types
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    11:47 AM
    I'm stumped on this - I am updating my casework. I created a shared door panel family for a flush panel, then save-as and modified to get a glass inset and a raised panel. I load a panel into the base cabinet, set my constraints, flex it then load into the project. So far, so good. But - if I try to change the panel it doesn't behave as expected, either breaking completely or moving around erratically in both the project environment and the family editor
    Attached Thumbnails Attached Thumbnails Nested Family Location Shifting When Changing Types-basecabinet-2.png   Nested Family Location Shifting When Changing Types-basecabinet-1.png
    Attached Files Attached Files
    August 9, 2011
    Louisville, KY
    6,190
    11:47 AM
    Update - if I constrain the door panels to a different RP it seems to work... Any reason why?
    Member Barth's Avatar
    December 2, 2013
    301
    08:47 AM
    The problem lies in the door panel. Remove equality constraint for height. Make it grow "up", in one direction. Lock all dimensions. Place equality constraint to lock the symbolic swing line's midpoint. Reload panel into the base family and lock the bottom of the panel at the cabinet base.
    August 9, 2011
    Louisville, KY
    6,190
    11:47 AM
    Thanks. I'll take a look see
  1. changing sink types from architecturtal to MEP
    By fifthtexas in forum MEP - General
    Last Post: February 4th, 2015, 03:15 PM
  2. Revit OpEd: Changing Column Types and Copy Monitor
    Last Post: December 5th, 2014, 06:15 PM
  3. Revit 2013 is not de-selecting walls when changing types.
    By jcoe in forum Architecture and General Revit Questions
    Last Post: June 14th, 2013, 01:15 PM
  4. Family Types and Nested Familes
    Last Post: June 6th, 2012, 02:58 PM
  5. Create Similar followed by changing types
    By gaby424 in forum Architecture and General Revit Questions
    Last Post: August 17th, 2011, 07:37 PM
