Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree8Likes
Thread: Angular Parametrics
    Member doni49's Avatar
    February 26, 2013
    Jefferson City, MO
    441
    04:53 PM
    Angular Parametrics
    I'm trying to make a family to represent an occupancy sensor. It'll only be shown in plan view.
    The attached image shows what the boss wants it to look like. I'm trying to make the arrow parametric so that I can choose the angle (it represents the direction the sensor faces).
    I'd prefer to be able to pick a glyph of some sort and manually change this angle but I'll type it if I need to.
    I've tried everything I can think of. But although the reference lines seem to change ok when I update the angle, as soon as I lock lines to the reference lines and try to flex it, it breaks.
    I've tried both symbolic lines (what I think I should be using) and model lines.
    Attached Files Attached Files
    Senior Member
    August 19, 2011
    New Hampshire
    503
    05:53 PM
    Host the arrow head reference lines to the arrow body reference line. Host the lines to each individual reference line.
    St. Louis, MO
    1,954
    04:53 PM
    Try this one. ( Revit 2015 )
    I simplified it. Grouped Ref Lines , named the Group Arrow.
    Deleted your dimensions and parameters, then placed an angular dimension. Flexes fine.
    Orlando, FL, USA
    3,098
    05:53 PM
    Quote Originally Posted by cliff collins View Post
    ... Flexes fine.
    Nope. Change the angle to 45, then to 0, then to 45. It breaks. I don't think the group can be locked to the pivot point in this way.
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    04:53 PM
    How about this one?
    cganiere likes this.
    Orlando, FL, USA
    3,098
    05:53 PM
    Quote Originally Posted by PijPiwo View Post
    How about this one?
    Yup. This is correct, and with the correct shape (ellipse instead of circle).
    Also, attached is the version I did last night, and an image showing the family in all directions. I made it as a Lighting Device family, with a Generic Annotation nested in, that scales up and down with the scale of the view. The family posted in the original post of this thread was not going to scale with the view because it was just a model category with no annotation. The rotation of the arrow does not need more than one parameter and one reference line. The lines are simply hosted on the line (including the little arrow lines).
    Attached Thumbnails Attached Thumbnails Angular Parametrics-2015-07-28_21-23-25.jpg
    February 26, 2013
    Jefferson City, MO
    441
    04:53 PM
    Thanks Alfredo. I have a couple questions about this family.
    1. I don't see any reference lines in there. Show how did you lock the lines to the right angle?
    2. How did you lock the arrow head lines to the right angle, length and location along arrow body?
    3. I placed the family in my project and it worked great! Until I printed that is. Even though the arrow is masked by the Mask Ellipse in Revit, the mask does NOT hide the arrow on the print.
    EDIT: Disregard #1 & #2. I previously missed your comment about hosting the line on the arrow body line.
    Orlando, FL, USA
    3,098
    05:53 PM
    Quote Originally Posted by doni49 View Post
    3....I placed the family in my project and it worked great! Until I printed that is. Even though the arrow is masked by the Mask Ellipse in Revit, the mask does NOT hide the arrow on the print
    Hmm... I was not expecting that. I saw it working fine on the screen, but I did not print any view. I don't have an answer for this at this moment.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    05:53 PM
    It's not like the arrow needs to be inside the ellipse. Could just drag the line out of the ellipse and the gap will be negligible all around. Unless scaling would interfere with that.
    St. Louis, MO
    1,954
    04:53 PM
    After all the time spent on this--wouldn't a Tag w/ leader work just as well?. Tag by Category or Multi-Category Tag? Put info / Mark inside Motion Sensor Family? Or nest an annotation family in the Motion Sensor Family?
    Made a quick GM Tag, Oval shaped w/ leader.
    Created quick GM for Motion Sensor, use Mark of MS ( or OS for Occupancy Sensor, etc.)
    Done. Rinse. Repeat.
  1. Angular Reporting Parameters in Adaptive Components
    By hroark in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 17th, 2014, 10:56 AM
  2. Angular Facade, how would you go about it?
    By nPoika in forum Architecture and General Revit Questions
    Last Post: March 27th, 2014, 12:41 AM
  3. Does Autocad do 2d parametrics like Revit?
    By Amstrad in forum Architecture and General Revit Questions
    Last Post: December 18th, 2013, 05:51 AM
  4. Dimension - Angular
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: October 29th, 2013, 04:02 PM
  5. Inputting Angular Dimensions
    Last Post: November 26th, 2012, 05:02 PM
