Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By sdbrownaia
  • 1 Post By tuekappel
Thread: Rendering a Nested Light Fixture
    July 7, 2015
    1
    09:42 AM
    I am building a specialty equipment family that has a light in it. I nested a light family in the specialty equipment family, but it is not rendering the light in the project. I have not tried this before and cannot seem to find any posts covering this topic. Does anyone know how to get the nested light family to render?
    Thanks!
    St. Louis, MO
    1,954
    08:42 AM
    I answered this on the Adesk Forum:
    Try placing the same light fixture (temporary as a test) and see if it renders by itself.
    If it does, then there is something wrong when it's nested into the equip. family.
    If it does not, try moving the 'light source' (yellow thing in the light family) outside of its 'housing'--as this can sometimes cause it not to render in the scene. You can alos try giving the lense of the light a 'self-illuminating' (glowing) material.
    December 20, 2010
    1,036
    10:42 AM
    Make sure the light fixture is set to "shared" so you can control it once loaded into the project.
    mifioso likes this.
    Member ScubaMan's Avatar
    July 6, 2015
    197
    07:42 AM
    From my experiences lights are broken in revit. If what Cliff and Sdbrownaia said does not work change the watt light settings to 3,000 - 5,000 and see if that works. Yes that is a crazy amount of power in real life but for revit that is sometimes normal.
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    315
    03:42 PM
    Quote Originally Posted by ScubaMan View Post
    ^this is especially true, if you are "mixing", Sun and Artificial. I.e. sunshine and light fixtures. The sunlight is so much stronger, that it's impossible to render the scene with correct photometric values. Here the 5000 watt light fixtures come in handy :-)
    Ning Zhou likes this.
  1. Light Fixture not Recognizing Light Source
    By BD Mackey in forum Architecture - Family Creation
    Last Post: February 4th, 2015, 11:37 PM
  2. Light Fixture Visibility
    By fannm1 in forum MEP - General
    Last Post: October 3rd, 2014, 01:55 PM
  3. Piping over Light Fixture - HELP!
    By jolingj in forum MEP - General
    Last Post: April 24th, 2014, 07:36 PM
  4. help with lighting fixture rendering
    By barry in forum Architecture and General Revit Questions
    Last Post: June 26th, 2011, 12:20 PM
  5. Light Fixture Tags
    Last Post: February 18th, 2011, 07:53 PM
Tags for this Thread
