Results 1 to 4 of 4
Thread: Show Revit Family Insertion Point in Project
    March 9, 2014
    59
    08:26 AM
    Hello,
    Is there a way to find the insertion of a family when placed in a project? I know I could just place the family and see where it is on my cursor, but I need to draw lines from the insertion point. In AutoCAD, you can designate a line to start from an insertion point. Was curious to know if there was anything comparable in Revit.
    Thanks!!
    May 14, 2012
    Where the plains meet the mountains
    392
    06:26 AM
    By insertion point, do you mean the "origin" as defined by the origin reference planes? Unless those reference planes are set to "not a reference", you should be able to snap to them in the project (and thereby snap to their intersection).
    Out of curiosity, what type of family is this? Depending on the family, it might be more likely that you'll want to create the family such that you can draw the lines from corners, edges, centers or other definite part of the family, rather than a nebulous "insertion point" (after all, even in ACAD, a block could be created with no relevance to 0,0, rendering the insertion point useless).
    March 9, 2014
    59
    08:26 AM
    Thanks for the reply! Yes, the point of origin. They are all casework families.
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    06:26 AM
    I have sometimes used invisible symbolic lines to represent the origin. They show up when the element is selected and pre-selected.
  1. changer le point d'insertion d'un poteau
    By tibo in forum Forum Français
    Last Post: December 2nd, 2014, 09:08 PM
  2. Door not centered on insertion point........
    By doni49 in forum Architecture - Family Creation
    Last Post: October 17th, 2013, 03:03 PM
  3. Linking multiple drawings - Insertion Point
    By domsib in forum Architecture and General Revit Questions
    Last Post: March 5th, 2013, 12:45 PM
  4. Can't change family origin point, family loads into project as hidden lines
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 1st, 2013, 03:51 PM
  5. Restricting an insertion point of a family?
    By KWilkinson in forum Architecture and General Revit Questions
    Last Post: December 7th, 2012, 03:12 PM
