Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree1Likes
Thread: How to control Yes/No with Void cut Solid ?
    April 21, 2014
    32
    04:52 AM
    I created a Solid extrusion and a Void extrusion. I would like to turn on / turn off the Void by Yes/No parameter so that the Solid would appear in the attached image. Anyone could help me ? Thanks a lot.
    How to control Yes/No with Void cut Solid ?-h2.png How to control Yes/No with Void cut Solid ?-h1.png
    My file : http://www.mediafire.com/download/63...ramic_tile.rfa
    December 21, 2010
    Phoenix, AZ
    2,644
    09:52 PM
    You can't turn it off but you can push it outside of the solid so it no longer intersects with a length parameter.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    12:52 AM
    The only way I know of to control that is with a separate set of dimensions to move the void out of the shape it is cutting. I've attached a ghetto fabulous example to demonstrate the general idea.
    Attached Files Attached Files
    Dave Jones likes this.
    10,362
    11:52 PM
    This gets really fun, when the VOIDS start to show up in the project environment, btw. Weve had it happen with several families in Parkland, where you see the solids and the outline of the orange voids, in all view. Its a graphical regeneration glitch, because renaming the FAMILY in the project browser fixes it in all views. So occasionally, we have to just rename some families, lol.
    But these guys are correct that right now its the only way.
    April 21, 2014
    32
    04:52 AM
    Thanks for reply. Unfortunately my Revit is version 2014 so cannot open your file .
    But I found a solution : copying the Solid extrusion ( original Rectangular shape ) and Paste to the same place, then cut it by the void, add parameter " Void " to this Joined Solid... Well done.
    Ceramic tile
    Gold Coast
    2,631
    02:52 PM
    Quote Originally Posted by nguyenkien View Post
    Ceramic tile
    uh, I can't believe that actually works. Obviously it does, but to me it seems counter-intuitive. I've always done it as others have described above, so angle and depth can be controlled with parameters rather than a dragging on shape handles.
    April 21, 2014
    32
    04:52 AM
    Unfortunately I could not open the file of cellophane to see... But it seems that I've done as him ? I used angle and depth to control with parameters ( Angle, a b ) as my attached file.
    Gold Coast
    2,631
    02:52 PM
    Ceramic tile
    My bad I'm still surprised the visibility parameter carries through, as the visibility property is non-existent for voids (or after swapping from solid). Subsequently the solid/void subcategory property for both disappear when you join the geometry. Learn something new everyday I guess
    December 21, 2010
    C.LONDON
    4,396
    05:52 AM
    Would you post your family *(on here)?
    Sounds to me like you're either :
    doubling the extrusions up, (one for cut, one for non-cut)
    or
    cutting solids with solids
    ...both are as good a solution as any (as Aaron noted, the moving-void method has it's view regens issues, not to mention the implied exaggeration of the "overall geometric extent" of an element) - but something you'll want to be mindful of (as a workflow choice) with more complex forms/families.
    *EDIT : Original mediafire link noted, ignored & request (to post to forum) edited.
    Junior Member dingohot's Avatar
    February 24, 2014
    34
    01:52 PM
    Here is my post about this issue.
    hope it helps.
    Enjoy Revit: Visibility of Void
  1. Solid Fill problems
    By rodqaq321 in forum Architecture and General Revit Questions
    Last Post: February 17th, 2014, 01:16 PM
  2. Replies: 0
    Last Post: November 10th, 2013, 02:15 PM
  3. Quick Filter - Solid & Void
    By mahisanu in forum Architecture - Family Creation
    Last Post: September 16th, 2013, 07:54 AM
  4. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 02:13 PM
  5. I can't cut a solid from a void form. Please help!!!!
    By cezaryp in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 6th, 2012, 07:58 PM
