Results 1 to 4 of 4
Thread: Question on manipulating/editing system families.
    November 18, 2013
    1
    08:26 AM
    Hey Guys,
    Pretty new to Revit and I just have a couple of questions regarding system families. How could I go about adding a masking region to an elevation, section, and plan callout? I'm just trying to clean up my drawings and I'm finding them difficult to read as hatch regions are interfering with the text. Also for section cuts, is there a way to break the line and manipulate the section line in a way that is similar to plan detail callouts? This is a fairly large project that is well on its way and I would rather not add masking regions to the plans as its time consuming and more susceptible to change or even create a brand new family since it would take time to switch everything over. Any input would be greatly appreciated, and again please bear with me as I'm a noob when it comes to Revit.
    December 21, 2010
    Phoenix, AZ
    2,576
    08:26 AM
    Callouts (elevation, section, etc.) use standard annotation families. Figure out which families yours are using and add the Masking Region there.
    Not sure what you're after regarding "a way to break the line and manipulate the section line." You can Split Segment on a section line to get it to jog in plan... is that what you're after?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    10:26 AM
    Welcome to RFo and the wonderful world of Revit.
    In addition to what GM posted, are you just trying to turn off the fill regions? You could turn them off by filter or just turn off the pattern entirely in your Visibility Graphics (VG). Can you post an image of what you're trying to clean up? That would help us give you the best answer.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,960
    10:26 AM
    If it's only Text that you're worried about, you can create a Text Type that's set to Opaque, so the Text would hide the Filled Region instead of vice versa.
  1. Editing families downloaded from the internet
    By efficiencydesign in forum Architecture and General Revit Questions
    Last Post: March 11th, 2014, 09:11 AM
  2. Manipulating Graphical Column Schedules
    By MartinGT in forum Structure - General Questions
    Last Post: February 19th, 2014, 02:12 PM
  3. Editing Familes Question
    By Jock in forum Architecture and General Revit Questions
    Last Post: November 6th, 2013, 02:19 PM
  4. Fire protection system editing
    By felipe.villete in forum MEP - General
    Last Post: November 1st, 2012, 10:26 AM
  5. Editing Multiple Families
    By Craig Howie in forum Architecture and General Revit Questions
    Last Post: October 6th, 2012, 06:18 AM
