Results 1 to 8 of 8
Thread: Cannot cut Model-in-place ! Help me.
    August 12, 2011
    80
    06:02 PM
    U created a mdel-in-place by Sweep, anh used a void extrusion to cue it. But can not ! Anyone get what is wrong ???
    Thac mac
    Coeur d Alene, ID
    4,814
    11:02 AM
    Some shapes just cannot be cut with a void....it happens. You have to model things a bit differently then join afterwards for it to work.
    Gold Coast
    2,631
    04:02 AM
    Quote Originally Posted by thaihoalu View Post
    Thac mac
    try moving the extents of the void out beyond the edges of the sweep element. It may be lean modelling but sometimes Revit doesn't like it if the edges of voids align with edges of solids.
    August 12, 2011
    80
    06:02 PM
    I tried... but anything change !
    There is always a reason fot what happening... Finally, Revit is still not perfect.
    Gold Coast
    2,631
    04:02 AM
    Find the perfect anything and you'll never have to work another day in your life. If you'd still like help you find a solution to your problems then maybe as Michael suggested you could try modeling things differently and report back your results, or you could upload your family or (purged) project file for someone to have a look at.
    August 12, 2011
    80
    06:02 PM
    But I have loaded my file : Thacmac.rvt in my first post.
    Gold Coast
    2,631
    04:02 AM
    Sorry I didn't see that. It would seem that the upper vertical line in your sweep is causing the issue, altering it slightly away from vertical as shown
    allows cutting without errors
    One would think this shouldn't be an issue, but Revit isn't perfect now is it Your primary roof shape could be created in other ways but I'm not sure of your final requirements as your uploaded file didn't include any void forms. Can you provide better details of where you're going with this?
    Attached Thumbnails Attached Thumbnails Cannot cut Model-in-place ! Help me.-untitled.png
    August 12, 2011
    80
    06:02 PM
    Well, I followed your instruction and got a good success. Thanks for help.
    Simply I created a roof by picking an opening cut from another roof, then painted it with another material.
    You have another way to make it ?
    Attached Thumbnails Attached Thumbnails Cannot cut Model-in-place ! Help me.-h1.png   Cannot cut Model-in-place ! Help me.-h2.png   Cannot cut Model-in-place ! Help me.-h3.png
  1. As-built Model using In-place family
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2018, 09:36 PM
  2. Spiral Sweep Model-in Place
    By sungwoox87 in forum Architecture - Family Creation
    Last Post: May 10th, 2017, 03:13 AM
  3. Assign material to Model in Place
    By como in forum Architecture and General Revit Questions
    Last Post: May 12th, 2016, 03:11 PM
  4. how to Cut model in place component
    By jean_francois_nant in forum Structure - General Questions
    Last Post: August 8th, 2013, 06:50 PM
  5. Corner Panel Model In Place
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: June 26th, 2011, 09:53 PM
