Results 1 to 7 of 7
Thread: Nested Family Parameter not working in Parent Family
    March 24, 2014
    2
    01:18 AM
    Hi all,
    I have a window parent family that I have created with panel families nested into it. For some reason the "panel depth" parameter isnt working properly with my interior window panels. The exterior panels work fine. The panel depth parameter is in both the nested and parent family. I've tried troubleshooting this several times but with no luck. The revit family is attached. Any help/tips would be appreciated.
    Attached Files Attached Files
    Member doni49's Avatar
    February 26, 2013
    Jefferson City, MO
    441
    06:18 AM
    What exactly is it doing that tells you it's not working?
    Never mind. I see what you mean. I changed Panel depth in the parent family properties and the child family still says Panel depth is the same as before.
    Coeur d Alene, ID
    4,802
    04:18 AM
    One worked, and one didn't when I adjusted the panel depth.....I changed the one that didn't to none then back to panel depth and it worked...
    February 26, 2013
    Jefferson City, MO
    441
    06:18 AM
    That's really odd. I changed the child family so that it wasn't looking to the parent parameter and just typed in a new dimension. It worked and I saw the panel get thicker.
    So i put it back to using the parent parameter. Now the depth matches what the parent parameter is. I changed the parent parameter again and once again the child didn't change.
    February 26, 2013
    Jefferson City, MO
    441
    06:18 AM
    But now change the parameter at the parent level. The child stays unchanged.
    Coeur d Alene, ID
    4,802
    04:18 AM
    Oh...yeah, that is messed up....
    Well, unless I have 3' walls I can't test it out in a project...it all crashes
    March 24, 2014
    2
    01:18 AM
    Thanks for looking at the family. I finally got it to work. There was some parameters in the child family that wasn't associated to parameters in the parent family. I linked those parameters and now it works. Thanks again!!
  1. Nested adaptive component family wont flex in parent family (Revit 2013)
    By Steve_Bennett in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 22nd, 2014, 11:45 PM
  2. Masking Region within nested family not working
    By Darken Rahl in forum Architecture and General Revit Questions
    Last Post: April 12th, 2012, 08:13 PM
  3. Nested Family parameter link lost
    By mdradvies in forum Architecture - Family Creation
    Last Post: October 16th, 2011, 10:41 PM
  4. Nested Family and Material Parameter
    Last Post: September 8th, 2011, 09:30 PM
  5. Visibility parameter and nested family: bug?
    By jbenoit44 in forum Structure - Family Creation
    Last Post: August 30th, 2011, 03:23 PM
