Results 1 to 6 of 6
Like Tree6Likes
  • 1 Post By Andrew K
  • 4 Post By dingohot
  • 1 Post By cellophane
Thread: Hanging Lights on Slopes
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    06:33 PM
    I've seen it hinted before that there's a way to build light fixture families so they behave like they would IRL when placed on a sloped ceiling, but I can't find any information on how. For example, a ceiling fan has a cover plate that is flush to the ceiling, and then the fan hangs straight down from that. I know there's the "always vertical" option, but that only helps so much when you want the fixtures to look right in sections, renderings, etc. The one idea I had was to nest one family that's set to "always vertical" inside another family that's not, but it didn't work. Does anyone have any ideas how to do this, or if it even is possible? Thanks.
    Senior Member
    August 19, 2011
    New Hampshire
    503
    08:33 PM
    It certainly can be done.
    I normally utilize the following procedure:
    Face Based Component.
    Model out items that stay flush with the surface in the Parent family.
    Use a Right Elevation to set up a rotating Reference Line, locked to the point where it needs to rotate.
    Nest in a lighting fixture that has a length-adjustable element to represent the chain/wire/pipe hanger.
    Nest separate lighting element if necessary.
    Host nested lighting fixture to rotating Reference Line. Rotate element to match reference line angle (if necessary).
    Test for errors.
    Rotate element using space bar when loaded into project to get proper orientation.
    Feel free to disassemble the attached family of a ceiling fan.
    Attached Thumbnails Attached Thumbnails Hanging Lights on Slopes-slopelighting.jpg
    Attached Files Attached Files
    cellophane likes this.
    January 18, 2013
    Utah
    354
    06:33 PM
    Ah, very nice. Would be nice if it could be done without manual input, but better than nothing. With a little trig, you could set it up to be able to enter in the slope of the surface instead of the angle.
    Junior Member dingohot's Avatar
    February 24, 2014
    34
    09:33 AM
    You can make it with adaptive component.
    here is a post for you.
    Enjoy Revit: Gravity In Revit
    hope it helps.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    08:33 PM
    Quote Originally Posted by dingohot View Post
    hope it helps.
    NICE! I really need to learn how to make AC...
    dzatto likes this.
    February 24, 2014
    34
    09:33 AM
    Thanks. you can make lot's of things with AC.
  1. Replies: 0
    Last Post: May 21st, 2013, 08:45 AM
  2. Roof slopes
    By cve60069 in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2012, 11:03 PM
  3. Hanging lamp..How to create??
    By timOthyj in forum Architecture - Family Creation
    Last Post: November 27th, 2012, 02:44 AM
  4. Joist with slopes
    By alexo4141 in forum Structure - Family Creation
    Last Post: December 2nd, 2011, 12:02 PM
  5. Can't get hanging light fixture to correct height.
    By kristiang in forum Architecture - Family Creation
    Last Post: November 1st, 2011, 02:06 PM
