Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Dave Jones
Thread: Curtain Panel TAG position
    October 23, 2013
    São Paulo, Brasil
    18
    07:28 PM
    Hi all!
    How can I add dimension parameters inside a Curtain Panel Tag family to adjust tag position?
    Gold Coast
    2,619
    07:28 AM
    Quote Originally Posted by bartok View Post
    Hi all!
Name:	curtain panel tag.jpg
    option a: move it manually
    option b: nest your tag family into a parent tag family of the same category and lock/ align the origin reference planes to instance based offset reference planes in the parent family. Don't forget to link your identifying parameter through as well.
    October 23, 2013
    São Paulo, Brasil
    18
    07:28 PM
    If I try to insert a family tag into another I got this message:
    Can't create this kind of element in this view in the current mode.
    Gold Coast
    2,619
    07:28 AM
    Now I'm at work with Revit in front of me it indeed seems you can't do as I suggested. I've never actually needed to do what you're trying i just move my tags manually.
    I've attached a tag family that will do what you want, notice the label itself is grouped with two invisible lines to which the dimensions are attached.
    I'm not necessarily recommending this workflow but the family does do what you asked for, so your mileage may vary...
    Attached Files Attached Files
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,491
    02:28 PM
    I move curtain panel tags all the time but just do it with SV (select all instances in view) and move them all at one time. I've never had an occasion to have to move multiple tags to lots of different locations on the face of a curtain panel. Occasionally I move one or two to avoid them being obscured by other annotation.
    d.stairmand likes this.
    October 23, 2013
    São Paulo, Brasil
    18
    07:28 PM
    Thanks elton!
    With invisible lines works perfectly!
  1. transparent curtain panel?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: March 5th, 2013, 10:12 PM
  2. Sticky Notes: Curtain Wall Basics - Empty Curtain Panel
    By Sticky Notes in forum Blog Feeds
    Last Post: June 14th, 2012, 02:45 PM
  3. Curtain Wall Panel
    Last Post: November 27th, 2011, 09:05 PM
  4. Curtain panel problem
    By Tomcsie in forum Architecture - Family Creation
    Last Post: November 20th, 2011, 09:41 AM
Tags for this Thread
