Results 1 to 8 of 8
Thread: Nested annotations on roof hosted families
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,419
    12:37 AM
    Is there any way to keep nested annotations in a roof hosted family parallel to the view, rather than parallel to the roof plane? The nested annotations look fine on a flat roof, but when the family is hosted on a sloped roof they don't show in plan. Keep vertical doesn't work because it keeps the whole family vertical, and I only want the annotations to stay perpendicular to the level, rather than the roof. If I have to I can put the annotations in the project, but I'd prefer not to because it is difficult to keep lengths and placement consistent.
    December 21, 2010
    Phoenix, AZ
    2,580
    11:37 PM
    You can but it's some work. This link should point you in the right direction. Andekan » Blog
    May 3, 2012
    1,401
    08:37 AM
    Use an alway vertical family to keep the annotation flat and put all the 3d stuff in a sub family.
    Put the sub family on a rotating reference line and set the angle with an instance parameter.
    Means you need to measure and fill in the angle whenever you place the family but the annotation will always work.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,419
    12:37 AM
    I'd rather try nesting the annotation, because that would be easier than trying to set the angle and remembering to set the slope for every roof instance (I'm trying to make a cricket family). Hopefully at some point they will add a feature that allows you to have elements that move with the host and elements that remain horizontal/vertical regardless of the host.
    May 3, 2012
    1,401
    08:37 AM
    I think you will have the same problem, just that you will be setting the annotation angle instead of the model angle...
    May be possible to use a "Strong Reference" ref line and use Align in a section view to set the angle.
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,419
    12:37 AM
    Unfortunately it seems that it is impossible (as of Revit 2014) to do what I am trying to do, a roof cricket that adjusts to the roof slope with annotations to indicate slope direction.
    Why can't we use the project based tag slope? Revit will not let the slope arrow be placed in the right location, it wants to tag the slope parallel to the cricket, we need the arrow to be perpendicular to the edge of the cricket.
    The suggestions in this thread do not work. I tried multiple nesting options for the annotations, including those mentioned in this blog post. The annotations won't adapt to a a varied angle. I can't host annotations on a plan whose tilt is modified to match the roof slope in the project. I can not constrain the path of a swept blend, which creates the the cricket, to a reference line without changes in slope breaking the association, therefore preventing "keep vertical" from working
    The fact that hosting to face or model elements can not be mixed with model elements and annotations that remain parallel to the view is quite frustrating, and I hope it gets fixed.
    December 21, 2010
    Phoenix, AZ
    2,580
    11:37 PM
    From what I've seen and how I work crickets (modified sub elements of floor slabs) the arrow will point at the valley of the cricket if it's been modeled correctly.
    Attached Thumbnails Attached Thumbnails Nested annotations on roof hosted families-cricket_example.png
    jmk
    jmk is offline
    December 31, 2012
    NM, USA
    1,419
    12:37 AM
    We use roofs, not floor slabs for the roof, and using sub elements means you have to calculate the height of each point, rather than just being able to specify the slope. As much as I hate to say it, it is easier to use dumb slope lines and crickets that host to the roof then spend time recalculating slopes if walls move.
  1. Replies: 0
    Last Post: September 5th, 2013, 01:45 AM
  2. Ceiling hosted families that create havoc in Groups
    By twilkins in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2013, 03:01 PM
  3. Linked file annotations appear above models and annotations in main model..
    By josephpeel in forum Architecture and General Revit Questions
    Last Post: May 15th, 2013, 01:41 PM
  4. Nested wall hosted family to align with top/bottom of wall
    By JasonWallis in forum Structure - General Questions
    Last Post: January 24th, 2013, 08:51 AM
  5. Replies: 0
    Last Post: November 7th, 2012, 12:15 AM
Tags for this Thread
