Results 1 to 3 of 3
Thread: Quick Filter - Solid & Void
    Junior Member mahisanu's Avatar
    March 12, 2011
    19
    11:27 AM
    December 21, 2010
    C.LONDON
    4,392
    12:27 PM
    Hi Mahisanu - thanks for your contributions - but perhaps you should request your blog be added to the feeds, rather than manually replicating the posts here as separate threads (with no discussion).
    Member Barrie's Avatar
    August 3, 2011
    Kent, UK
    217
    12:27 PM
    I wouldn't recommend creating sub categories just for selection purposes. If a sub category is already required in the project environment then it could prove useful. Looking at your family as an example, I would create induvidual families for cabinets and nest them into into a container although I probably wouldn't even do that and just save the arrangement as a group. You would then find that each family will have less solids and voids to manage.
  1. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 02:13 PM
  2. Replies: 0
    Last Post: September 12th, 2012, 09:15 AM
  3. I can't cut a solid from a void form. Please help!!!!
    By cezaryp in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 6th, 2012, 07:58 PM
  4. Override walls with solid color and pattern by filter
    By KimArndt in forum Architecture and General Revit Questions
    Last Post: September 16th, 2011, 01:26 PM
  5. Fan Hood in Solid Modeling
    By Gabriel Black in forum MEP - General
    Last Post: April 11th, 2011, 12:58 PM
Tags for this Thread
