Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Structural Beams (Length)
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    12:19 PM
    I'm trying to create a composite beam (i.e. (3) 2x10) where the number of members would be parametric using an array. I've done this sort of thing before, but it requires the nested family being arrayed to be controlled directly by the host's parameters (if the size needs to be parametric). This wouldn't be a problem, except that the Length parameter in the host beam family I'm using (copied from the dimensional lumber beam family) seems to have no relation to the beam's length once loaded into a project. Any solutions?
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    01:19 PM
    Don't use a beam family? Try creating them all from a generic model family, then set the category to 'structural framing'. That way, there's no parameters or anything. You can create just the ones you need.
    January 18, 2013
    Utah
    354
    12:19 PM
    Yeah, that's plan B. I was hoping to use a beam family because it stays connected to columns.
    dzatto's Avatar
    December 9, 2010
    5,234
    01:19 PM
    Try creating a new parameter. Of course, you can't name it Length (and you can't get rid of parameters already in a family template anymore). But, you could use Beam Length or something like that.
    Nantes, France
    1,380
    08:19 PM
    if nested beams are shared, you should get length in schedule.
    January 18, 2013
    Utah
    354
    12:19 PM
    The problem I'm running into is getting the nested beams to stretch with the host beam. The length parameter in the host beam seems to have no correlation to the length of the beam in a project; linking the nested beam length parameter to the host beam length parameter has no effect. I've tried changing the length parameter of the nested beam to an instance and then locking each end to the same ref planes that stretch the form that was already in there, but such a method doesn't seem to work when arraying the nested family.
    Nantes, France
    1,380
    08:19 PM
    I was refering to a shared nested family, so that you will schedule them in the project. Link mark parameter between host and nested will help you sort things in schedule.
    Gold Coast
    2,626
    04:19 AM
    Quote Originally Posted by kowen1208 View Post
    Unless im missing something while having a is there any reason you cant use a beam system?
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    328
    11:19 AM
    kowen1208,
    did you ever find a solution? I'm trying to build up something similar (I actually tried what you are doing with both wood and steel studs, reverted to just arrayed extrusions). I've fought this over and over and can't find a fix.
    Steve Stafford has this thread from a couple of years ago Revit OpEd: Family Puzzler - Beam and Family Type Parameter
    And there is a similar problem with columns with a fix. Revit Rants: Revit 2012 & Nested Structural Columns Workarounds
    Julien, the point isn't really scheduling, if anything you'd schedule it as a (3)2x6 bundle, not individual pieces.
    Elton, we are talking about (3) wood members that effectively act together as a beam. So the beam system would be (in this case) 4.5" wide with 1.5" equal spacing. Very hard to manage when you might have dozens and impossible to tag on plan. Most graphic conventions have it looking like a single beam also, not three lines so close together.
    I'm guessing the fix is to build up a similar family outside the OOTB using either the generic model or structural framing. Then just re-using the type catalog from the dimensional lumber.
    I'm dying to know why this is so hard. I am fairly certain there is some magic (i.e. some crazy code I don't understand) with all those reference planes at the ends of the member that will allow it to work.
    My .02, your mileage may vary.
    January 18, 2013
    Utah
    354
    12:19 PM
    My solution is to have separate families for each quantity. I.e. a family for one member, a family for two members, etc. Not what I was hoping for, but it's really not that bad, since I've never seen anything higher than four.
  1. Cant load structural beams and columns..
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: January 29th, 2019, 12:22 AM
  2. Beams NOT snapping to beams at same elev. but with different ref. plane
    By sebaldsl in forum Structure - General Questions
    Last Post: March 2nd, 2012, 01:01 PM
  3. Structural Columns Visibility og Length in Properties
    By ptranberg in forum Structure - General Questions
    Last Post: February 15th, 2012, 02:19 PM
  4. IFC - how to export length instead of cut length on framing
    By leetkinda in forum Structure - General Questions
    Last Post: August 17th, 2011, 05:38 PM
