Results 1 to 7 of 7
Thread: Using a profile parameter to define a sweep profile within a family
    May 15, 2013
    4
    06:10 AM
    I have a simple family I built to insert a recessed aluminum handle into a cabinetry element, I want to be able to change the profile of the handle using a family parameter to select from a range of profiles I have loaded into the family.
    I have made a profile type parameter which picks up the various loaded profiles however I can't make my sweep use this parameter to select the profile it uses.
    Any suggestions?
    Matt.
    Attached Files Attached Files
    Junior Member engel_hg's Avatar
    October 9, 2011
    Manila,Philippines
    48
    02:10 AM
    I hope this help. try to use Yes/No Parameters on your handle and just create a type parameters showing that profile that you want.
    May 15, 2013
    4
    06:10 AM
    Sweep profile defined by parameter
    Quote Originally Posted by engel_hg View Post
    ...try to use Yes/No Parameters on your handle and just create a type parameters showing that profile that you want.
    Do you mean make multiple sweeps and assign a yes/no visibility parameter so only the one I want is visible?
    October 9, 2011
    Manila,Philippines
    48
    02:10 AM
    Yes that is what i mean..
    May 15, 2013
    4
    06:10 AM
    Thanks for that - I would prefer to make the profiles relate to a parameter as it is a bit more elegant but that is a good workaround.
    10,341
    01:10 PM
    Profiles cannot use Family Type parameters, unfortch. If they are recessed make the recess a face based family that has the void and profile in it, and use the FT parameter to select different FB families and profiles.
    Sent from my iMaller using Forum Runner
    May 15, 2013
    4
    06:10 AM
    Yep that was my conclusion, I was hoping some bright spark knew a way to do it.
    It seems like you should be able to as they include a profile parameter in their standard parameter types...
    Laaaaaaame.
    What can you actually use the profile parameter for if not this?
  1. Chnage profile of sweep in nested family
    By jh75 in forum Structure - Family Creation
    Last Post: March 15th, 2016, 04:51 PM
  2. Replies: 4
    Last Post: March 14th, 2013, 02:31 AM
  3. Replies: 0
    Last Post: February 28th, 2013, 11:15 PM
  4. 3D Sweep - keep profile vertical
    By cellophane in forum Architecture - Family Creation
    Last Post: October 11th, 2012, 01:55 PM
