Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Andrew K
Thread: Change Family Type once created
    Senior Member domsib's Avatar
    April 30, 2012
    586
    05:38 PM
    How do I change my family type.
    I've created a Air Handling Unit on a General Template and want to change it to Mechanical Equipment.
    As its on the General Template it isn't showing up in my HVAC views so I would like to change it to mechanical because I then know it will show up.
    Can this be changed?
    Senior Member
    August 19, 2011
    New Hampshire
    505
    01:38 PM
    Click on the component icon in the Home tab that has a folder in the lower corner.
    Attached Thumbnails Attached Thumbnails Change Family Type once created-changetype.jpg
    jungle1101 likes this.
    April 30, 2012
    586
    05:38 PM
    Quote Originally Posted by Andrew K View Post
    Worked as you mentioned. Thanks
  1. Can't change family origin point, family loads into project as hidden lines
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 1st, 2013, 03:51 PM
  2. How can I change the line type of a family?
    By Andres Franco in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 13th, 2012, 08:31 AM
  3. Building Coder: Change Section View Type and Hide Cut Line
    Last Post: May 22nd, 2012, 09:15 AM
  4. Replies: 0
    Last Post: March 16th, 2012, 03:15 PM
  5. can i change the type of width of window into instance?
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: October 19th, 2011, 12:19 AM
