Results 1 to 5 of 5
Thread: Move Pipe Connectors in family
    Senior Member domsib's Avatar
    April 30, 2012
    586
    02:45 PM
    Can anyone look at the image and tell me why the pipe connectors position themselves centre of my cube and cannot be moved.
    I require the connect at the top of the cube to be nearer to one of the edges and cannot move it.
    How do I move it?
    Senior Member
    August 19, 2011
    New Hampshire
    505
    10:45 AM
    Place it by workplane or attach it to another small extrusion so you can control the location through parameters. Placing by face sets it in the center of the face.
    April 30, 2012
    586
    02:45 PM
    Quote Originally Posted by Andrew K View Post
    It says it is placed by workplace when I try to reassign it. So it cannot be moved when checked or unchecked.
    Senior Member
    August 19, 2011
    New Hampshire
    505
    10:45 AM
    You'll choose how to place it when placing the connector initially. If you're trying to change a By Face connector to a Workplane connector it won't work (that I've been able to find). You have to delete the connector and replace it with the proper placement method.
    Attached Thumbnails Attached Thumbnails Move Pipe Connectors in family-byworkplane.jpg
    April 30, 2012
    586
    02:45 PM
    . Just tried this and it worked as you said. Thanks Andrew
  1. exporting pipe layout to DWG fittings move about
    By gcowan in forum MEP - General
    Last Post: January 22nd, 2016, 01:44 PM
  2. Fittings don't move with pipe, lost connectivity
    By hhpham73 in forum MEP - General
    Last Post: December 31st, 2012, 05:28 PM
  3. Unable to move a swept extrusion in REVIT family
    By Jimidy in forum Architecture and General Revit Questions
    Last Post: December 28th, 2012, 06:08 PM
  4. How to move this family vertical along the vertical?please,i tried to move it but...
    By ncharchitect in forum Architecture - Family Creation
    Last Post: December 12th, 2012, 08:09 AM
  5. Pipe Connectors move........
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: October 3rd, 2012, 09:20 AM
