Results 1 to 3 of 3
Thread: Door Family template - how to delete "pre defined" parameters (or change them)
    October 30, 2012
    95
    02:45 AM
    I am creating a door using the door template and I want to make the "frame Material" (which is a predefined parameter in the door template) from an instance to a type parameter.
    I know I can just create my own frame material parameter that is a type. But, now I have 2 frame material parameters once i've loaded into the project.
    Can anyone help me.
    Thanks!
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    689
    03:45 PM
    Sorry, can't do it. Revit has default "system" parameters in families and they are what they are.
    Coeur d Alene, ID
    4,744
    12:45 AM
    One of my wishes is the ability to hide parameters in a family that won't be seen in a project....This is one of the reasons as I have instance parameters like Frame: Finish and Panel: Finish that are linked to materials and simple text instance parameters for Frame: Material and Panel: Material...
  1. change instance parameter w/ "Edit" for multiple views/sheets
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 08:56 AM
  2. Door properties "From Room: Number" does not change when door flipped
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: September 19th, 2012, 07:48 PM
  3. Did Ref Plane "positive" change?
    By Gordon Price in forum Architecture - Family Creation
    Last Post: December 31st, 2011, 10:04 AM
  4. Door schedule: 6'-0" x 7'-0" --> (2) 3'-0" x 7'-0"
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 14th, 2011, 10:06 PM
  5. Family Type Parameters and "Export Family Types" functionality...
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: September 7th, 2011, 07:05 AM
