Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By snowyweston
Thread: Wall finishes problem
    August 13, 2012
    4
    10:20 PM
    Hi guys.
    I'm new on the forum, and new to Revit, so I apologise if this seems like a daft question.
    I'm trying to create a new, very basic wall type for my project. It's core has 57mm insulation, that's fine, but when it comes to putting on the 0.7mm steel finish on, it tells me that the finish layer needs to have a thickness. Now, correct me if I'm wrong, but i thought 0.7 mm was a thickness. I know this because it works a treat in AutoCAD Architecture!
    I've had a look, and apparently you need a minimum thickness of 1.6mm, but that doesn't suit my requirements.
    If anyone has any work arounds for this, I would be very grateful!
    Thank you
    United States
    1,632
    02:20 PM
    Hi David, welcome to the forum!
    That's got to be a little frustrating. As a work-around, how about if you made the insulation 56.1mm and the finish 1.6mm (or whatever it would work out to if the finish is on both sides of the insulation)?... that would maintain the actual overall thickness of the wall. Would that really mess anything up?
    December 21, 2010
    C.LONDON
    4,382
    10:20 PM
    What scale of drawing, and lineweights, are you going to be using that will clearly delineate 0.7mm thickness of the steel?
    I would personally model the wall at 60mm - using one material, a "57mm Insulation w/ 0.7mm Steel Lining" that has a nice shiny metal render appearance and a identity information that reads the same when using a material tag.
    iru69 likes this.
    October 22, 2011
    Budapest, Hungary
    49
    11:20 PM
    And if he wants to schedule the volume of insulation and steel? Its similar to the "line is too short" issue, and i think it will never be solved...
    August 13, 2012
    4
    10:20 PM
    I was thinking about making the insulation 56.1, but then as mentioned by Tomcsie, I'll need to create a schedule. It's not necessarily the drawing that I need to be accurate, as I'll be doing details to show the construction. It's the schedule that will be created. I could just create a stand alone schedule, but then that negates the point of using Revit.
    Frustrating indeed!
    Member cerb0z's Avatar
    July 5, 2011
    Belarus, Minsk
    244
    12:20 AM
    Well, you can use a formula for your steel finish material. And yes, this is very frustrating limitation.
    August 13, 2012
    4
    10:20 PM
    Quote Originally Posted by cerb0z View Post
    How would I go about creating a formula? I'm new to Revit and only know the basics.
    December 21, 2010
    C.LONDON
    4,382
    10:20 PM
    Quote Originally Posted by davidjb82 View Post
    Is it a composite panel product - or one that you're designing?
    If it's the former, you won't (surely) need to schedule them as separate quantities (like you wouldn't with insulation-backed plasterboard, since it's a product). If it's the latter, then what accuracy will your schedules need to be? Will you be modelling to such an extent that dimensionally the schedule of your wall element will truly reflected the required quantities to the point where 0.7mm variance will be apparent? Good luck too you if you are.
    Otherwise, as suggested, you'd do well to consider approaching the problem differently (in light of Revit's current limitations) - for example, the metal is a panel sheet - typically ordered in height/width by shape and by thickness, not by a volume. The area of your (Revit) composite wall, or it's separate height and length values, will be enough for any estimator - and any volume "calculation" you provide would be unnecessary.
    If you're calculating embodied energy, or have even more esoteric considerations, that "require" this level of accuracy, consider also that the equations and methods to produce those are pretty much rule-based, to "best scenario" conditions, with a certain degree of tolerance. If it's the U-Value of the "wall" calculate the combine value for the wall, insulation+metal, for your data input - don't try to (use Revit) to split it up.
  1. Problem with wall based family.
    By XepheX in forum Architecture - Family Creation
    Last Post: April 10th, 2019, 02:27 PM
  2. Wall Clean Up Problem
    By designimpressions in forum Architecture and General Revit Questions
    Last Post: April 30th, 2012, 06:24 AM
  3. Identifying wall buildups problem
    By maskelllee in forum Architecture and General Revit Questions
    Last Post: March 14th, 2012, 06:04 PM
  4. (Diagrammatic) Wall Finishes Plan
    Last Post: December 8th, 2011, 01:25 AM
  5. problem in inserting door into curtain wall ?
    Last Post: September 27th, 2011, 02:44 PM
Tags for this Thread
