Results 1 to 7 of 7
Thread: Curtain Wall Mullion Orientation
  1.    #1
    April 24, 2012
    3
    01:34 AM
    I am working on a faceted tower in which large expanses of panels will be following specific planes. I would like the outside face of the mullion to be parallel with the plane and the other three sides of the mullion to be parallel with the floor. It seems as though I can do one or the other but not both by manipulating the orient to host or orient to global z parameters. I have attached the family with nested mullion family. I expect the facet angles to change throughout the process so would prefer if this was automatic, based on host, rather than providing an angle input parameter to manually set it.
    Best,
    Steve
    Attached Files Attached Files
  2.    #2
    Orlando, FL, USA
    3,140
    02:34 AM
    Quote Originally Posted by stevomatic View Post
    ...I would like the outside face of the mullion to be parallel with the plane and the other three sides of the mullion to be parallel with the floor. ...
    Is this the idea?
    Attached Thumbnails Attached Thumbnails Curtain Wall Mullion Orientation-2019-08-12_16-59-28.png
  3.    #3
    April 24, 2012
    3
    01:34 AM
    Is this the idea?
    Almost. Rotate the curtain wall 90 clockwise.
  4.    #4
    Orlando, FL, USA
    3,140
    02:34 AM
  5.    #5
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,523
    11:34 PM
    I think that the OP is looking for a mullion that has an exterior face that follows the plane of a near vertical glazed panel but the inside face follows the plane of the FACE of slab. So, you're illustration is correct if rotated 90 degrees clockwise. It would be an interesting exercise to have a mullion that could do this but that would be parametric to handle any face of glazed panel to face of slab angle variances.
  6.    #6
    Orlando, FL, USA
    3,140
    02:34 AM
    Something like this, A or B?
  7.    #7
    April 24, 2012
    3
    01:34 AM
    That's it precisely. We have both conditions.
  1. Curtain Wall Mullion Parameters
    By Noam_r in forum Architecture - Family Creation
    Last Post: May 31st, 2018, 03:31 PM
  2. Curtain Wall Mullion Mitering
    Last Post: April 16th, 2015, 11:40 PM
  3. Curtain wall mullion
    By mona miller in forum Architecture and General Revit Questions
    Last Post: July 15th, 2014, 01:22 PM
  4. Mullion Orientation for curtain system applied on a mass
    By o12k in forum Architecture and General Revit Questions
    Last Post: April 15th, 2013, 10:42 AM
  5. Curtain Wall Mullion Takeoffs
    Last Post: August 6th, 2012, 07:11 PM
Tags for this Thread
