Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By kamranmirza
  • 1 Post By Mengelmn
Thread: Masonry Frame Elements Facade - Adaptive Components / Parametric / How to ?
  1.    #1
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    538
    06:50 PM
    Hi All,
    Looking for a steer on how to go about creating this type of a facade with masonry frame elements that are straight and also curve around a corner with a radius and a straight portion within the same frame. Plus they need to be set up to have varying (modular) lengths, widths and heights (as per storey heights).
    I'm thinking some kind of adaptive components ? And could I stay clear of curtain walls (as this design curves around the corners) so it would follow a line ?
    Plus later on to insert glazing with framing within the elements.
    Grateful for a modelling direction that would work. Thanks in advance.
    Masonry Frame Elements Facade - Adaptive Components / Parametric / How to ?-masonry-frame-elements.jpg
  2.    #2
    10,277
    12:50 PM
    I would use basic families for it. Wouldnt bother with Adaptive Components.
  3.    #3
    January 12, 2011
    London, UK
    538
    06:50 PM
    Hey, thanks so much for that. Sometimes the best advice is the simplest.
    Twiceroadsfool likes this.
  4.    #4
    May 30, 2015
    203
    12:50 PM
    If that corner was is radiused I would consider using adaptive to accommodate early design studies. Other wise I’ve had better luck with line based generic models.
  5.    #5
    10,277
    12:50 PM
    I wouldnt use either. Making a parametric unhosted family that responds to a radius, is pretty straightforward, if you are halfway decent at math. Heck, even if you arent, its pretty easy. And then, everyone is designing in clean whole numbers, and not whatever whackamole stuff they can click on, with the AC.
    Line Based (for radii based objects) guarantees you have to be good at math. But thats how my curved wall protections are built. In hindsight, i wouldnt do them that way, again.
  6.    #6
    May 30, 2015
    203
    12:50 PM
    What ever your solution, one should also look at who and for what purpose these families are used for. If it’s only for “documentation” purposes then I’d fully agree with Aaron. If it’s use is more about design studies and may be used across various forms, surfaces and iterations, I’d leverage adaptive and line based families. Though once into documentation phases would swap to other families.
    elton williams likes this.
  1. Adaptive Components - How to cut?
    By hauliod in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 7th, 2018, 06:28 AM
  2. Adaptive facade component help!
    By sierrastar in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 10th, 2016, 08:01 PM
  3. Huge help for a parametric perforated metal facade
    By giannifrullo in forum Architecture and General Revit Questions
    Last Post: June 10th, 2015, 09:31 PM
  4. Distorted adaptive components hosted on parametric familes
    By billiam in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 26th, 2014, 08:16 PM
  5. Family content for timber frame elements
    By jorge in forum Architecture - Family Creation
    Last Post: July 19th, 2011, 06:37 PM
