Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By Alfredo Medina
Thread: Drain with 3 AP
    December 17, 2012
    Stuttgart
    25
    08:33 AM
    Drain with 3 AP
    Hi guys,
    I try to create a kind of drain with 3 adaptive points. Between the AP I have created reference Lines. On the reference lines are hosted 3 reference points (with normalized 0 or 1 to have them at the end of the line). Hosted on each of these RP are AP Profiles. Because I need a rotation parameter I have nested the profiles. The profiles are AP families with one Adaptive points, and RP hosted on the AP. The RP are connected with model lines
    Problem1: I cannot select 2 Profiles and generate a form
    Problem2: I cannot use a reporting parameter of the angle to drive the angle of the profile
    Attached are some pictures with description. In the onedrive link is the revit project
    One Drainage is without the rotation parameter in the profile: the volume creation works
    The other drainage has the profiles with rotation parameter and a correct angle but the form creation does not work in the family.
    Revit 2019 file + high res pics: https://1drv.ms/u/s!Ar9xxoyu3-ZhkaxR...ieKsA?e=14eEMw
    Any tips how to continue?
    Thanks,
    Thomas
    Attached Thumbnails Attached Thumbnails Drain with 3 AP-15-06-_2019_16-45-27.png   Drain with 3 AP-15-06-_2019_16-45-33.png   Drain with 3 AP-15-06-_2019_16-45-37.png
    May 30, 2015
    204
    01:33 AM
    Quote Originally Posted by Thommynat0r View Post
    Hi guys,
    Thanks,
    Thomas
    I would suggest you only host a single profile at the midpoint of one of you path lines. Then create the swept geometry. It should split your mitered condition equally as you are attempting without adding additional parameters and constraints.
    Orlando, FL, USA
    3,140
    02:33 AM
    If you want a drain that follows a series of points, in this way, do this:
    • create adaptive points 1, 2, 3...
    • create a reference line that goes from point to point.
    • host a point on a reference line,
    • host a generic model family, work-plane based, with the shape of the profile that you want, hosted on the new reference point.
    That is all. Then, in the project, click 1, 2, 3... and this will create a continuous gutter or drain, with the profile.
    Having said that, notice how many extra steps you have taken so far, that are not necessary and/or that actually make the family not usable:
    1) a "profile" that is also an adaptive family with an adaptive point, (not good)
    2) a "profile" that is hosted at every point (not necessary unless you need the profiles to rotate around the host point)
    3) an angular dimension to control the angle between two lines driven by adaptive points, (not possible)
    4) normalized curve parameter to keep a point at the end of a line, (not needed)
    Thommynat0r likes this.
    December 17, 2012
    Stuttgart
    25
    08:33 AM
    • host a generic model family, work-plane based, with the shape that of the profile on the new reference point.
    Thanks Alfredo for your help! I'll try it asap
    btw: It's not for me, I just try to solve a problem from someone else in another forum The goal is to create something like this:
    The profile is not perpendicular to the reference line, how can I change that?
    I get always an error when I want to create the form.
    As soon as I create a straight line it works:
    but it breaks as soon as I place it in the project
    Creating the profile manually with model lines in the adaptive family - then I can create the form
    /e: Got it the mistake was to make the nested family "Always vertical" =)
    Orlando, FL, USA
    3,140
    02:33 AM
    Profiles for extrusions in adaptive families work better if they are generic families, workplane based, not always vertical.
  1. Adaptive Trench Drain
    By Elias in forum MEP - Family Creation
    Last Post: January 5th, 2016, 06:02 AM
  2. Trench Drain Simple Shape
    By CRapai in forum MEP - Family Creation
    Last Post: December 1st, 2015, 12:28 PM
  3. Simple drain pan family
    By aykhan9 in forum Architecture - Family Creation
    Last Post: October 16th, 2014, 08:42 PM
  4. Simple modelling of drain
    By DeanB72 in forum Structure - Family Creation
    Last Post: January 30th, 2013, 03:18 PM
  5. Floor Drain
    By cwwalder in forum MEP - General
    Last Post: February 24th, 2011, 02:12 PM
