Quote Originally Posted by Debo View Post
but the hole over the bridge is really challenging
Marco
Forget about the hole.......or rather, model the entire structure as a continous surface, and then "drill the hole" with a void.
Or, if you want to panelize your surface, you can just place empty panels in the position of the hole.
