Results 1 to 5 of 5
Thread: Curtain Panel Pattern Based family
    November 20, 2016
    Bangalore, India
    6
    11:44 AM
    Hey,
    I have a curved sloping panel on which I created a pattern(square) and applied it. Some edges coming out of the geometry. Please check the reference image and advice me.
    Thank you.
    Attached Thumbnails Attached Thumbnails Curtain Panel Pattern Based family-curtain-panel.jpg   Curtain Panel Pattern Based family-curtain-patten1.jpg
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    317
    07:14 AM
    In your first image, your pattern ends with half a tile, at the top and bottom edge. Revit has a hard time deciding how to split your tile, so you'll always get artifacts like that.
    Design a half tile, if thats how you want your pattern to be at the edges, and apply that half tile by hand.
    Or re-think your design, do you really want to end with a half-tile? In a real-life building that would look awful.
    November 20, 2016
    Bangalore, India
    6
    11:44 AM
    Hey Tuekappel,
    thanks for the reply.
    I have similar situation happening in other part of the panel where it is coming correctly.
    It's nice that you point out the half tile design idea. I know it will look awful and practically the fabricator will not agree to make half-tile design. In my case I have half-tile situation on top and bottom which i can manage by aligning grid end to end and changing the pattern dimension, but still there will be half-tile situation in any one side of this shape(polygon) because in my situation i am not making panel according to pattern, i have restricted panel space.
    Let's not consider the practical application. Just consider there is a irregular space(panel) and pattern. I am just wondering if there is a better way to make a pattern with flexible dimensions or with using formula.
    Attached Thumbnails Attached Thumbnails Curtain Panel Pattern Based family-sadsajndjsa.jpg
    Gold Coast
    2,514
    04:14 PM
    Quote Originally Posted by Lochan91 View Post
    Hey Tuekappel,
    Divided surfaces can only use a singular spacing in any direction (thats what an array is). You could split your mass faces and use divided surfaces with unique arrays per surface -but thats still another family as well.
    April 19, 2018
    1
    06:14 AM
    Qwd1
    Enviado desde mi RNE-L03 mediante Tapatalk
  1. Pattern Based Curtain Panel - Keep Panel Extrusion aligned
    By christianism in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 12th, 2018, 02:49 AM
  2. Pattern Based Rectangular Curtain Panel - Split into Triangles based on Distortion
    Last Post: March 7th, 2018, 08:19 AM
  3. Curtain panel pattern based
    By Lochan91 in forum Architecture and General Revit Questions
    Last Post: November 20th, 2016, 04:20 PM
  4. Replies: 2
    Last Post: January 26th, 2015, 02:57 AM
  5. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
Tags for this Thread
