Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree2Likes
Thread: Chord Length Constraints
    April 22, 2017
    62
    11:10 AM
    I'm trying to figure out how to input trig into my Family Type Dimension Parameters. As of now, I have a simple A^2+B^2=C^2 equation which is getting me part of the way there. What I want is for the highlighted line to be parallel with the bottom line, no matter what angle the left side of the component becomes. Is anyone able to give me a hand with this? See screenshots for examples.
    The 6" dimension needs to be the same on both sides.
    Attached Thumbnails Attached Thumbnails Chord Length Constraints-right-corner.png   Chord Length Constraints-left-corner.png   Chord Length Constraints-constraints.png   Chord Length Constraints-family-constraint.png   Chord Length Constraints-panel-bottom.png
    Orlando, FL, USA
    3,038
    12:10 PM
    It would be useful to have more information about what you are trying to do. It seems that you are using adaptive points. What is the final result? Some kind of trapezoid with adaptive points and a certain angle at the ends?
    April 22, 2017
    62
    11:10 AM
    I’ll update in the morning, but for now I will tell you that the adaptive component is a cladding ACM panel. There is more to the component than I have shown and I’ll provide a screenshot of what it looks like on a model tomorrow.
    This is a fairly common occurrence with our panels and if I can get this formula figured out, it will help our team tremendously. We’re still very new to Revit.
    9,911
    11:10 AM
    Quote Originally Posted by JT44 View Post
    Chord length is easy to do, just takes different formulas based on h (R - dist to chord perp to arc), and a few variables. A bunch of my window families have that in them. Doesn't matter adaptive or not, the math is the same. I'll look at one in the morning.
    Aaron Maller
    Director
    Parallax Team, Inc.
    JT44 likes this.
    Kingdom of Denmark
    4,204
    05:10 PM
    JT44 likes this.
    April 22, 2017
    62
    11:10 AM
    Here's what the component looks like on the model, the highlighted part. The part directly to the right of it is the same part but mirrored - these parts will be epoxied together at the corner.
    The issue I'm running into is the bottom termination, as it is crooked because my equation is wrong.
    Attached Thumbnails Attached Thumbnails Chord Length Constraints-canopy-below.png   Chord Length Constraints-canopy-front.png   Chord Length Constraints-canopy-bottom.png
    April 22, 2017
    62
    11:10 AM
    Your trig for right triangles is exactly what I need! I think lol
    Orlando, FL, USA
    3,038
    12:10 PM
    And that was an adaptive family? Seems that it could have been easier to do and to use as a generic family.
    April 22, 2017
    62
    11:10 AM
    They’re generic families but they need to be adaptive because of what we will be doing with Revit. We will be manufacturing these panels when the time comes.
    Orlando, FL, USA
    3,038
    12:10 PM
    I still don't see the need to use an adaptive family for this molding. It could be simplified using generic families. A "family 1" that is the profile, and a "family 2" that is the parametric sweep. "Family 1" can be done as a single closed shape (B) or a "hollow" shape with thickness (A). "Family 2" needs a path (P) that can have parameters for leg 1 and leg 2. See illustrations.
    Attached Thumbnails Attached Thumbnails Chord Length Constraints-2018-12-01_12-50-15.jpg   Chord Length Constraints-2018-12-01_12-55-48.jpg   Chord Length Constraints-2018-12-01_13-01-31.jpg
  1. Revit OpEd: Revit 2016 - Truss Chord Rotation
    Last Post: May 15th, 2015, 04:15 AM
  2. Limit Pipe length to practical standard length
    By amarkrish108 in forum MEP - General
    Last Post: January 8th, 2014, 02:27 AM
  3. Floor truss w/ top chord and bottom cord bearing
    By Jondoe941 in forum Structure - General Questions
    Last Post: April 19th, 2013, 04:23 PM
  4. IFC - how to export length instead of cut length on framing
    By leetkinda in forum Structure - General Questions
    Last Post: August 17th, 2011, 05:38 PM
  5. DBL Pitched top chord joists
    By chaos2010 in forum Structure - General Questions
    Last Post: May 28th, 2011, 02:32 AM
