Results 1 to 3 of 3
Thread: Revit Rendering
    January 18, 2017
    Eden Prairie, MN
    76
    04:32 PM
    Revit Rendering
    We've been using revit to make quick renderings of projects which works fine. We now need a high resolution rendering to be used on a construction site sign. To make one that size takes days for Revit to render. Is there a way to get a high resolution rendering from Revit any faster, or do we need to use a different rendering software?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,141
    05:32 PM
    First I would check with the sign company and see what they need. Those large scale signs are frequently fairly low-res (72-150dpi) since they are viewed from a distance and often while in the car on the move. Once you know what you need, then I'd figure out how to approach the rendering.
    Junior Member Kate's Avatar
    September 4, 2014
    Ann Arbor, MI
    46
    05:32 PM
    You might have luck with Enscape - I've used it on the occasional project where we have some rendering requirements. It works with Revit really nicely and doesn't have a huge learning curve, and I think you can do up to 4k renderings.
  1. Rendering in Revit
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: November 26th, 2014, 12:18 PM
  2. Revit & rendering
    By nick_h in forum MEP - General
    Last Post: December 12th, 2013, 09:05 AM
  3. Replies: 0
    Last Post: August 17th, 2013, 06:15 AM
  4. Revit Rendering
    By Chang Lee in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 1st, 2011, 09:12 PM
  5. Rendering in Revit...
    By Sami in forum Rendering and Gallery
    Last Post: June 21st, 2011, 07:47 PM
