Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Like Tree2Likes
Thread: Possible to create a poly-carbonate luminaire family shaped like a cloud?
  1. #11
    10,127
    07:14 AM
    When I'm back in the office I can, sure.
    Aaron Maller
    Director
    Parallax Team, Inc.
  2. #12
    September 19, 2017
    Seattle, WA
    37
    05:14 AM
    Seconding Alfredo's request.
    The Tab-Select for a shared/nested family is a great tip for those who don't know. But the last time I went down that route, I ran into the trouble with shared connectors defaulting to the internal origin. For scheduling, shared families are great. I just had a hard time justifying the headache of trying to properly route anything to the shared connectors.
  3. #13
    10,127
    07:14 AM
    Ahh, i see the issue. So, im partially wrong: You can assign the items to the Electrical system (power, duct or switch system), but the connectors (electrical / conduit) wont allow you to connect to them. Weird, because i thought i remembered testing this years ago, and tab-selecting presented the connectors. Well thats a bummer. I guess its only going to work for items that arent getting Conduit or Wiring run to each element. Boo.
    Alfredo Medina likes this.
  4. #14
    Orlando, FL, USA
    3,093
    08:14 AM
    Not only it doesn´t work for conduit. It doesn´t work for pipe or duct either. (Tested in Revit 2019).
  5. #15
    June 7, 2016
    38
    04:14 AM
    The connector issue could be worked around because this fixture would be for the architectural model, where the shape and aesthetic is more important. The light fixture portion would be copy monitored (since its shared) by the electrical engineer in their model, at which point they could connect to systems and conduit all day.
  6. #16
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    648
    12:14 AM
    Ahh, i see the issue. So, im partially wrong: You can assign the items to the Electrical system (power, duct or switch system), but the connectors (electrical / conduit) wont allow you to connect to them. Weird, because i thought i remembered testing this years ago, and tab-selecting presented the connectors. Well thats a bummer......
    You're not going mad: Ive just tested this with some of our families and they work as expected in Revit 2017 , but not 2018 or 2019.
    I've lodged a support case for this
    Twiceroadsfool likes this.
  1. How do I create a Y shaped column?
    By dylanrevitq in forum Architecture and General Revit Questions
    Last Post: January 29th, 2018, 07:35 PM
  2. Ring shaped Lighting Family
    By BIM_grl in forum MEP - Family Creation
    Last Post: December 8th, 2017, 09:38 AM
  3. Door family - Can L-shaped Opening Cut be set to zero?
    By JGendell in forum Architecture - Family Creation
    Last Post: March 2nd, 2016, 07:34 PM
  4. Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    By Glenn Arne in forum Architecture and General Revit Questions
    Last Post: January 27th, 2016, 10:58 PM
  5. Alive in the Lab: Raspberry Pi: Poly want a cracker?
    By Alive in the Lab in forum Blog Feeds
    Last Post: October 12th, 2012, 11:15 AM
