Results 1 to 2 of 2
Thread: Adaptive Membrane Surface
    September 5, 2018
    1
    02:13 AM
    I am trying to create a tensioned membrane surface using generic adaptive family. The outside perimeters are fixed, but can move with shared parameters. The surface is flexing correctly, but it is very faceted using 'create form'. Is there a way to smooth the faceting, or is there a better way to create the surface/family?
    Please see attached RFA.
    Thanks
    Attached Files Attached Files
    Orlando, FL, USA
    2,962
    03:13 AM
    Welcome to Revitforum.
    The attached images show the process:
    1. Draw in 3d the contours of the desired shape
    2. Using the contours, get points at the correct places. All these points can be controlled by parameters using the Offset property of the points, from workplanes. No need to put dimensions in the view. Dimensions tend to "break" in these forms. Points don't break.
    3. Create reference lines to create forms. Use the rule of "paralellism", meaning, sets of lines, not parallel, but going in the same direction, kind of... parallel. Notice in the form "B" many of these reference lines are required, to avoid a faceted result.
    4. Create forms. This needs to be in 3 parts, the base, the transition, and the top.
    5. Load into projects and put material to the surfaces with wall by face.
    Attached Thumbnails Attached Thumbnails Adaptive Membrane Surface-2018-11-11_10-36-13_1.jpg   Adaptive Membrane Surface-2018-11-11_10-36-13_2.jpg   Adaptive Membrane Surface-2018-11-11_10-36-13_3.jpg   Adaptive Membrane Surface-2018-11-11_10-36-13_4.jpg   Adaptive Membrane Surface-2018-11-11_10-36-13_5.jpg
  1. How to Material Tag Membrane=0 ?
    By jihansh in forum Architecture and General Revit Questions
    Last Post: December 6th, 2017, 08:28 PM
  2. To manipulate one of two divided surface with adaptive component
    By leeway180 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 30th, 2015, 05:49 AM
  3. Replies: 0
    Last Post: May 21st, 2013, 03:15 AM
  4. Masses With Surface subdivide using adaptive component - keeping it speedy?
    By 411toaster in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 11th, 2013, 10:22 AM
  5. Turning off divids surface of Adaptive Component in Project environment
    By Parametric Snowman in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 18th, 2012, 08:56 PM
