Results 1 to 2 of 2
Thread: Easy way to grab exterior wall surface areas of Mass
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    07:17 AM
    Is there any easy way to grab the exterior wall surface area from a building mass? As far as i can tell, the mass doesn't even know what is exterior and what is roof unless you start applying mass floors.
    May 30, 2015
    200
    09:17 AM
    Quote Originally Posted by ryntau View Post
    Easy?
    If you are just assuming anything that is vertical is a wall one can explode the geometry, then filter by each faces “normal” direction. This is a simple method I use often. This can also be made so the normal could be with in a certain tolerance of vertical.
    If you had materials painted to these faces and wanted to filter based on that it is also possible - I don’t have this with and can look up tomorrow.
  1. In Place Mass Disappears when Subcategory is changed to Mass Exterior Wall
    By pmrossarc in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 26th, 2017, 09:41 AM
  2. Making wall face for just a part of Mass surface
    By zohreh in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 22nd, 2016, 06:45 PM
  3. Random slat on wall (Loblolly): Conceptual Mass and Curtain Wall/Surface
    By im4am303 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 15th, 2015, 09:45 PM
  4. Mass Surface
    By juangambino in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 26th, 2013, 03:33 PM
  5. Creating a schedule for floor areas - families and model in-place mass
    By calle_05 in forum Architecture - Family Creation
    Last Post: September 17th, 2012, 08:04 PM
