Results 1 to 6 of 6
Thread: Curved mass with compund curve roof
    April 12, 2011
    Chicago, IL
    523
    04:15 PM
    I'm trying to find a way to create this mass in Revit. The shape is a closed loop with vertical sides, but the roof curves up and down on both the inner and outer edges. I've tried playing around with swept blends and voids, but I'm not having much luck. I think part of the issue is that there are some radii that are smaller than the profile size would need to be. I'd love to get some ideas from those of you who do a lot more of this kind of work.
    Curved mass with compund curve roof-curved-mass.pngCurved mass with compund curve roof-mass-footprint.png
    Coeur d Alene, ID
    4,784
    02:15 PM
    Multiple roofs by footprint...that way you can align and adjust as needed. Which is the way it would probably be built.
    Think of where the beams would be located and a roof between each beam. Could probably do it with a conceptual mass as well where each corner can be adjustable.
    10,189
    04:15 PM
    Mass and Roof by Face.
    April 12, 2011
    Chicago, IL
    523
    04:15 PM
    This is for a proposal so a quick and dirty roof by footprint with shape edits might do the job, but I'd still like to figure out how to actually make this as a mass. That was by first thought for sure, but I was having a lot of trouble actually getting anything in the mass editor to resemble the shape I was looking for. Can you provide any more detail than "mass"?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    334
    09:15 PM
    Place points on a line, and then you can select the points as work planes. -when you select the (Path)line and the shapes you drew on those work planes, "create form", you'll get a sweep ( or rather a loft.)
    After that, you can manipulate the shape, add edges and profiles, but that only works with open-ended paths, not closed.
    Attached Thumbnails Attached Thumbnails Curved mass with compund curve roof-2018-07-05_1126.png   Curved mass with compund curve roof-2018-07-05_1129.png   Curved mass with compund curve roof-2018-07-05_1130.png
    April 12, 2011
    Chicago, IL
    523
    04:15 PM
    That's what I've been trying, but I think the issue I'm having is some sections of the path have radii that are too tight for the size profile I need. It will need to be a closed path eventually as well.
  1. Vertical Mass to conform to roof mass
    By Hilife in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 21st, 2015, 10:37 PM
  2. Non curve edges possible in Mass editor?
    By tzframpton in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: September 22nd, 2014, 07:44 PM
  3. In a curved mass how to turn only one edge to straight without affecting the mass ?
    By Diaa.Sabri in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 2nd, 2013, 10:34 PM
  4. Curved wall not attaching to curved roof...
    By roseman5285 in forum Architecture and General Revit Questions
    Last Post: June 1st, 2013, 08:40 AM
  5. Roof - Extrusion Along path - Conceptual Mass - 3D curve
    By kubbah in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 25th, 2013, 02:52 PM
