Results 1 to 3 of 3
Like Tree3Likes
  • 1 Post By elton williams
  • 2 Post By Dave Jones
Thread: How do you create a non-pattern curtain wall
    June 1, 2018
    3
    11:09 PM
    Ive been searching on youtube and everywhere but there is no tutorial on how to create a custom curtain wall which is not pattern based. As i will be using different shapes and sizes. Like the image. How would you apply the mullions to it as well? Thanks
    Sent from my SM-N920I using Tapatalk
    Gold Coast
    2,621
    10:39 PM
    Unless you stay with curtain wall system by face, using multiple faces to get multiple grid orientations, youll be modelling custom panels (parametric or static) for each condition and custom mullions alongside to get it work in a regular curtain wall panel family. You could even just draw a bunch of profile edited single panel walls and align all the edges (don't do that).
    Pattern based curtain panel is the right description for how that family type behaves. A single instance iterated over a grid. You could model a new family for each condition and place them manually (even on divided surfaces with AC's). Or just tab select a repeater placed AC and swap it out for a different type. Or even just use a flip control when your panel is a true left/right handing.
    Either way you need to identify all the parameters required to get your panels working correctly, and build that into your family types. Although implementation varies, generally speaking the way a regular curtain panel family behaves compared to an adaptive curtain panel is really not that different, they both stretch to fit.
    IMHO, curtain panel systems work well for concept design, which is why they were designed to work the way they do. As soon as it becomes a real project you're gonna want to work with the real thing. Size and scope of the project, modeling preferences and resourcing should tell you which way to go.
    Vicke likes this.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,491
    05:39 AM
    Quote Originally Posted by Vicke View Post
    Hi Vicke and welcome to the forum. I deleted you other duplicate post. When you are a new poster here your first 5 posts are moderated and sometimes, especially on the weekends, take some time to show up. So, be patient with us and keep posting questions
    cganiere and Vicke like this.
  1. Why is my curtain wall pattern based family behaving like this?
    By viratmanchanda in forum Architecture - Family Creation
    Last Post: May 20th, 2018, 08:37 AM
  2. Custom Curtain Wall Pattern
    By Arcitct in forum Architecture and General Revit Questions
    Last Post: March 6th, 2015, 07:04 PM
  3. Is there a way to schedule each panel in a Pattern Based Curtain wall?
    By viratmanchanda in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 22nd, 2014, 10:59 AM
  4. How to make a surface pattern on a curtain wall system panel able to move/align?
    By severett in forum Architecture and General Revit Questions
    Last Post: December 31st, 2013, 04:14 PM
  5. Pattern based curtain wall problem. Revit 2012
    By Williamjcooper in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2012, 11:00 AM
