Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Tapered Roof Mass
    Member BLothian's Avatar
    December 11, 2013
    Livingston, Scotland
    465
    10:14 PM
    Tapered Roof Mass
    I've got a building which has a flat roof with a 2° fall however at 1 corner of the building at the lowest edge of the roof, I have parapet walls which would prevent the roof draining (unless we provided a chute and hopper arrangement which is not gonna happen). Instead, I need to create another roof in this area to form a valley which will fall away from the parapet and force rainwater to collect in an adjacent secret gutter (not yet modelled on the images below). The roof build-up is a single ply membrane on rigid insulation and the additional roof could be formed by either:
    • tapered rigid insulation on top of the main roof insulation boards, or
    • same insulation boards as main roof on plywood on timber firring pieces on main roof structure
    Ultimately it's down to the contractor which method he will choose but for now I'm aiming to model the former. I need to create a roof which has a 2° fall which matches the main roof (to the underside) and another 2° slope which falls in a completely different direction. I don't think this can be achieved with a system roof via shape-editing so my next thought was to create a mass however I've never had to use masses before and I don't know if its possible to model the type of mass I need and if I can constrain it to specific slopes and directions. Any tips for the forum massing guru's would be appreciated. Alternatively, if there is a non-massing approach, I'm listening.
    Colours:
    Orange= Top surface edges
    Green= Underside surface edges (on main roof)
    Cyan= Vertical edges
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    05:14 PM
    A separate roof that is adjusted using modify sub-elements will work. Don't forget that you can use formulas in the temporary dimensions.
    Attached Files Attached Files
    December 11, 2013
    465
    10:14 PM
    Hi Chad, many thanks for the sample.
    It does seem to work but I'm not fully clear on some of what you've done.
    • On your roof cricket, you seem to have used pick walls for some of the roof sketch lines. I never use pick walls; I always use pick lines or draw the edge. Is pick walls fundamental to this roof creation in order for it to work?
    • I can't see how the slope to the underside of the cricket is applied to create the fall. There are no sketch lines with 'defines slope' applied . Am I missing something obvious?
    • I can see that you have used shape editing for the top surface however it does not have a constant slope which is what I'm trying to achieve. If there was only 1 vertice above the main roof it would be fine but because there are 2, I don't think shape-editing will give the constant slope aside from trial and error but hopefully I'm wrong on that.
    August 9, 2011
    Louisville, KY
    6,164
    05:14 PM
    Pick walls is habit, pick lines will work fine.
    The cricket is created as a flat roof, then moved so it is partially above the main roof and joined. Then move it down so the high point snaps to the main roof.
    You can then modify sub-elements and it will snap to the main roof where the two intersect. To get a single slope you will need a split-line (as far as I know) just because of the shape.
    https://www.screencast.com/t/K4DCqimL
    https://www.revitforum.org/architect...tml#post158836
    December 11, 2013
    465
    10:14 PM
    Ahh so that's why I couldn't see it! I wonder if a slight drawback to this method is if using a compound roof buildup. My only slight concern would be the waterproof membrane finish being visible in a section view sandwiched between the insulation layers. I'm not sure if layer function in the roof material would allow that to clean up or if it would need to be done as separate roofs (I don't have Revit opened right now but I'll check later).
    Thanks again
    July 10, 2015
    Boise, Idaho
    680
    03:14 PM
    I make a new roof with the foam adjustable. The mid highest point is typically modified to be 4" higher and the rest is adjusted to match the existing roof. As long as the slope works out, the exact numbers are (mostly) irrelevant. In the field they may build up a foam cricket, bodge something together out of scraps or purchase a pre-manufactured cricket. I gave up trying to get them to use what I called out years ago. At that point, it's out of my hands. So model it to match what you already have and hope for the best.
    St. Louis, MO
    1,954
    04:14 PM
    They way we do it:
    Membrane roof on Tapered Insulation. Set minumum thickness per code at roof drains ( if any).
    Shape edited roof for crickets. Show shape of geometry and pitch that you want on roof plan. Contractor will provide shop drawings for review/approval
    showing exactly how each layer will be cut/pieced together for final insulation installation.
    August 9, 2011
    Louisville, KY
    6,164
    05:14 PM
    Quote Originally Posted by BLothian View Post
    Thanks again
    Once joined you shouldn't see anything but the insulation. If you do, change the join order.
    December 11, 2013
    465
    10:14 PM
    Meant to say, there is no reason why you shouldn't be able to achieve this without the split as the 2 highest vertices can exist on the same plane in 3D space as the 2 lowest (which intersects with the main roof). Its just determining the correct Z-value of the of the 2nd highest vertex is otherwise you (should) get an interior edge.
    10,277
    04:14 PM
    Shaped Edited Tapered Insulation Roof Types, with Join Geometry, and some of the roofs modeled with larger extents than the final, so they can be carved out with Vertical openings, to guarantee the Slopes are spot on, and no approximated with Shape Editing (for the main roofs underneath).
    Oh, the fun things you can do with Shape Editing, and Join Geometry.
    Attached Thumbnails Attached Thumbnails Tapered Roof Mass-2017-03-27_11-23-22-slopes.png   Tapered Roof Mass-2017-03-27_11-23-43-slopes2.png   Tapered Roof Mass-2017-09-14_21-45-58.png   Tapered Roof Mass-2017-09-14_21-44-57.png
    d.stairmand likes this.
  1. Cannot create Mass Roof
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 23rd, 2015, 01:53 AM
  2. Vertical Mass to conform to roof mass
    By Hilife in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 21st, 2015, 10:37 PM
  3. Flat roof with tapered insulation
    By need4mospd in forum Architecture and General Revit Questions
    Last Post: June 20th, 2014, 02:02 PM
  4. Sloping roof structure and tapered insulation
    By max2527 in forum Architecture and General Revit Questions
    Last Post: September 5th, 2012, 01:04 AM
  5. Roof Modeling - Tapered Trusses
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: July 9th, 2012, 05:50 PM
