Results 1 to 5 of 5
Thread: Modeling site toposurface
    April 19, 2018
    2
    03:45 AM
    Can anyone help me with this toposurface? The elevation is supposed to start from 10' at the edge of the building and go up to 20', then taper down to 14' at the end of the site. I've tried split surface several ways, but the building still shows through the bottom. Any comments are appreciated.
    thanks
    Attached Thumbnails Attached Thumbnails Modeling site toposurface-toposurface1.png
    December 20, 2010
    1,025
    03:45 AM
    you just add points at the desired elevations in the locations where you want these changes to occur. then use the building pad tool to cut out the area where the building is. You shouldn't bee spliting the surface.
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    02:45 AM
    In 3D, topo surfaces don't display any thickness. The building showing through the bottom is normal behavior.
    January 19, 2012
    301
    02:45 AM
    Try this...turn on the Section Box. Once it cuts it you'll see the thickness.
    April 19, 2018
    2
    03:45 AM
    Thanks all for the help!
  1. Cleanup of Site Topo for Toposurface Model
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2018, 06:36 PM
  2. Toposurface/site problems
    By TooCaps in forum Architecture and General Revit Questions
    Last Post: November 9th, 2015, 12:01 AM
  3. Site Modeling
    By dzatto in forum Out There
    Last Post: January 27th, 2015, 06:49 PM
  4. site plan - toposurface
    By jenniferli in forum Architecture and General Revit Questions
    Last Post: July 31st, 2014, 02:01 AM
  5. Site Toposurface Workflow (relevent to any version)
    By GenreNomad in forum Architecture and General Revit Questions
    Last Post: March 27th, 2013, 06:05 AM
