Results 1 to 2 of 2
Thread: visibility doesn't work after using repeater
    July 20, 2011
    850
    02:02 AM
    i just noticed that after using repeater, visibility doesn't work for all individual members within repeater, but other members not using repeater are OK, looks like a bug to me! any solution or workaround?
    Attached Thumbnails Attached Thumbnails visibility doesn't work after using repeater-capture.png
    Member aristide's Avatar
    July 11, 2011
    Boston, MA
    74
    04:02 AM
    Visibility doesn't really work the same way one you hit Repeat.
    I've had more success with a Type Selection parameter. You'd be swapping the repeated Adaptive Component for an "empty" Family Type with no visible geometry, but the same number of Adaptive Points.
  1. shortcut doesn't work
    By philsogood in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2018, 02:38 PM
  2. tag doesn't work, why?
    Last Post: June 22nd, 2017, 02:21 AM
  3. Void form doesn't work
    By daliagregorova in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 16th, 2017, 07:42 PM
  4. Visibility Control of a Divided Surface Repeater Component
    By Barth in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 10th, 2016, 10:15 PM
  5. Filter doesn't work while rendeirng
    By rabbitcookies in forum Architecture and General Revit Questions
    Last Post: November 26th, 2014, 07:15 PM
