Results 1 to 2 of 2
Thread: Instance(xyz) vs Global(xyz)
    July 20, 2011
    850
    11:30 PM
    i try to change my 5 points AC roof truss to 3 points AC roof truss, well, i'm firm believer of "less is more".
    seems working except the inconsistent between rfa and rvt, i need to "rotate" column portion 90 degree in rfa so it will look OK in rvt
    i used Orients to Instance(xyz) in 5 points version, and Orients to Global(xyz) in 3 points version.
    anyone have idea what causes this bizarre situation? thanks
    Attached Thumbnails Attached Thumbnails Instance(xyz) vs Global(xyz)-roof-truss_3-ac-points_in-rvt.png   Instance(xyz) vs Global(xyz)-roof-truss_3-ac-points_zoom.png   Instance(xyz) vs Global(xyz)-roof-truss_3-ac-points.png   Instance(xyz) vs Global(xyz)-roof-truss_5-ac-points.png   Instance(xyz) vs Global(xyz)-roof-truss_3-ac-points_updated.png
    July 20, 2011
    850
    11:30 PM
    sort of working now after i used Global(z) then Host(xy), but i may still have to adjust Rotation Angle in rvt, perhaps it's unavoidable?!
    Attached Thumbnails Attached Thumbnails Instance(xyz) vs Global(xyz)-capture.png
  1. global parameters
    By Hoangtin in forum Architecture and General Revit Questions
    Last Post: September 4th, 2017, 11:47 PM
  2. RTC: Global Challenges
    By RTC in forum Blog Feeds
    Last Post: April 11th, 2017, 01:16 AM
  3. Building Coder: Voodoo Magic Retrieves Global Instance Edges
    Last Post: August 31st, 2016, 09:15 AM
  4. How to use global parameters?
    By andreas2 in forum Architecture and General Revit Questions
    Last Post: December 20th, 2015, 09:58 PM
  5. R2 Global Parameters
    By ryntau in forum Architecture and General Revit Questions
    Last Post: December 18th, 2015, 02:26 PM
