Results 1 to 4 of 4
Thread: Profile twisting with sweep
    December 15, 2010
    23
    08:58 AM
    I'm trying to create a sweep using a spline through points as the path, and using an adaptive component rectangular profile. The path is curving in different directions, but the resulting form shows the profile twisting towards the end of the sweep. What is the best way to control the profile orientation in a complex sweep? At the top, I want the profile to be oriented horizontally, and it's going vertical. Any help would be greatly appreciated.
    Attached Files Attached Files
    December 15, 2010
    23
    08:58 AM
    Bueller?
    Anyway to manipulate (rotate) the profile along the path in certain areas or do a loft along a path with different profiles? I've been trying to solve this with Dynamo, but no luck so far.
    March 21, 2013
    Phoenix, AZ
    275
    05:58 AM
    I'm rusty on ACs, but I think the issue you're trying to solve has more to do with adaptive points & point orientation than anything automation / Dynamo related. ACs certainly have ways to rotate a profile along a path, but you may need to create more than one path, sweep, etc in order to satisfy the arbitrariness of "certain areas" that you want.
    Have you tried the diagnostic tripod?
    https://knowledge.autodesk.com/suppo...F4E61-htm.html
    Seen this?
    https://www.revitforum.org/architect...gs-nature.html
    December 15, 2010
    23
    08:58 AM
    Thanks Chris. Sounds like that would probably work. I was trying to avoid having an extra step of creating an AC for this. After struggling enough with this, the geometry has been simplified a bit so that I don't need to use the conceptual design environment. Thanks for the reply. I will go back and try the AC in the next week or two just to see if it can do what I wanted.
  1. Profile Sweep, Family type profile parameter
    By spinxy in forum Structure - Family Creation
    Last Post: January 11th, 2016, 06:56 AM
  2. Parapet wall cap sweep twisting
    By Tony Marinou in forum Architecture and General Revit Questions
    Last Post: September 6th, 2013, 01:19 PM
  3. Using a profile parameter to define a sweep profile within a family
    By mattsim in forum Architecture - Family Creation
    Last Post: May 16th, 2013, 04:47 AM
  4. 3D Sweep - keep profile vertical
    By cellophane in forum Architecture - Family Creation
    Last Post: October 11th, 2012, 01:55 PM
  5. Sweep profile in wall
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: October 24th, 2011, 10:13 PM
