Results 1 to 2 of 2
Thread: How Can i Avoid Unwanted Segments in Free Form Massing Surface
    December 3, 2017
    3
    12:12 AM
    Exclamation How Can i Avoid Unwanted Segments in Free Form Massing Surface
    Hi all,
    I am creating a free form mass Surface.
    I need to create a single piece wall on that massing surface.
    But, when i am creating form, it is creating unwanted segments automatically. and as result i can't create single wall by face so, need to create walls by face as segments which is not what my boss wants.
    can anyone please help me about how can i avoid such unnecessary segments while creating this type of surfaces?
    The Image of my surface is attached below.
    Thanks and Regards,
    Dharmil Ranpariya
    Attached Thumbnails Attached Thumbnails How Can i Avoid Unwanted Segments in Free Form Massing Surface-segments-mass.jpg
    Orlando, FL, USA
    3,098
    05:12 PM
    One year after, one reply, yes, but better late than never:
    See illustration.
    • Image 1: in an generic model adaptive template, in plan view, locate five reference points hosted at the reference level, forming a triangle. Then draw (represented in red color) two splines of 3 points, and draw (represented in blue color), with 3d snapping activated, one reference line.
    • Image 2: in an elevation view, create 2 reference planes, such as "mid" and "top". Optionally, you can control the location of these two reference planes by parameters. Then select points and change their host to the corresponding host reference plane.
    • Image 3: select the two splines and the reference line, and do Create Form. The shape will be created smoothly without those unwanted edges.
    • Image 4: load into project and use Wall by face.
    • For parametric variations of the shape, you could change the location of the "mid" and "top" reference planes.
    Attached Thumbnails Attached Thumbnails How Can i Avoid Unwanted Segments in Free Form Massing Surface-2018-12-15_11-29-05.jpg
  1. Conceptual Massing- Question About VOID FORM
    By lamyazz in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 15th, 2017, 04:49 AM
  2. Modeling In-Place Masses, unable to see any massing form or colour!?
    By daveth in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 3rd, 2015, 06:46 PM
  3. Panel component sticks out of form's divided surface
    By igor in forum Architecture and General Revit Questions
    Last Post: June 12th, 2014, 07:33 AM
  4. In place massing joining two or more form
    By nelson13 in forum Architecture and General Revit Questions
    Last Post: September 16th, 2013, 05:05 AM
