Results 1 to 8 of 8
Like Tree5Likes
  • 2 Post By elton williams
  • 1 Post By MPwuzhere
  • 1 Post By elton williams
Thread: Can't apply curtain panels to massing surface
    October 17, 2017
    4
    11:41 PM
    Exclamation Can't apply curtain panels to massing surface
    Hi everyone,
    I am a beginner to Revit massing function and am wondering if there is any solution about my following question.
    I try to model some non-rectangular curtain panels and what I plan to do is modelling a rectangular curtain panel and apply it to non-rectangular massing surface. But system warns me that I cannot finish that operation.
    Attached is my screenshot for my working progress and curtain panel type.
    Thanks.
    Attached Thumbnails Attached Thumbnails Can't apply curtain panels to massing surface-q_screenshot.png   Can't apply curtain panels to massing surface-q_screenshot1.png
    Gold Coast
    2,436
    09:41 AM
    Curtain panels made from the rectangular curtain panel template won't skew or bend to fit non-planar or non-recrangular spaces. This is why you are getting the "cant make type" warning.
    You will need to make use of divide surfaces and adaptive curtain panels.
    Dave Jones and xuejhm like this.
    October 17, 2017
    4
    11:41 PM
    Hi Elton,
    Thanks for your quick reply. I got totally stuck in this problem. Do you have some detailed steps about how to make my model? Thank you so much!
    Coeur d Alene, ID
    4,530
    03:41 PM
    Lots of videos on youtube...
    This one is pretty extensive at over an hour... https://www.youtube.com/watch?v=xwX8Ekp8YuM
    xuejhm likes this.
    October 17, 2017
    4
    11:41 PM
    Hi MP,
    Thank you so much for your reply and this wonderful tutorial. Now I solved part of my issue but there still remain some part I don't know how to fix. For some special unit, I need to trim part of it instead of scaling. So do you have any ideas on how to trim it?
    Attached diagram shows that white part need to be remained and red part ought to be deleted.
    Thanks!
    Attached Thumbnails Attached Thumbnails Can't apply curtain panels to massing surface-002.png
    Gold Coast
    2,436
    09:41 AM
    Quote Originally Posted by xuejhm View Post
    Hi MP,
    Thanks!
    You could build the family to have a length parameter (0 > 1 in an adaptive panel) constraining the geometry along your vertical axis. Or in any direction really. Then you could set it to full length, half, or whatever.
    xuejhm likes this.
    October 17, 2017
    4
    11:41 PM
    Thanks Elton,
    Sounds like a great idea and I will try that. BTW, if I want to have some irregular cut in my unit(attached diagram), do you have some good ideas? Look forward to your reply!
    Attached Thumbnails Attached Thumbnails Can't apply curtain panels to massing surface-003.png
    Gold Coast
    2,436
    09:41 AM
    Thanks Elton,
    Very possible, just need to build your family the right way.
    Mengelmn likes this.
  1. New to Massing in Place - Walls created from surface can't be trimmed?
    By kescr in forum Architecture and General Revit Questions
    Last Post: February 10th, 2016, 06:43 PM
  2. Problem when i apply wall by face in Massing
    By ahmed3256 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 18th, 2015, 04:24 AM
  3. Adaptive Component Apply Curtain System and Miullions
    By nathanjh13 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 10th, 2014, 01:06 PM
  4. Massing trouble- walls don't join on a curved surface:::: Pleaseeeee help!!!!
    By margi85 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 13th, 2013, 08:24 AM
  5. help with massing plus curtain wall
    By barry in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 30th, 2011, 01:57 PM
