Results 1 to 2 of 2
Thread: Uneven pattern surface
    Lox
    Lox is offline
    April 4, 2013
    Christchurch, New Zealand
    157
    02:16 PM
    Hi all,
    I have created a form and then applied a pattern and then a brick panel family, problem is I am getting an uneven finish as per the attached image, any ideas can I can avoid this?
    Thanks all,
    Lox
    Attached Thumbnails Attached Thumbnails Uneven pattern surface-uneven-surface.jpg
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    744
    11:16 AM
    Um, wasnt there thread about this a while ago? Maybe its a tutorial somewhere people are doing. Anyway, if you search here, you will find the thread. I forget its name.
  1. Uneven surface when pattern family is applied and how to create openings in surfaces
    By Lox in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 12th, 2017, 06:43 AM
  2. Surface Pattern for Divided Surface
    By Mtel in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2015, 03:12 AM
  3. Surface Pattern or Pattern Component Family for Ceiliing Linework
    By nednarb in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 31st, 2015, 10:02 PM
  4. To delete part of surface but keep the same pattern and divide surface
    By leeway180 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 20th, 2015, 12:37 AM
  5. Surface Pattern for Topography
    By JCM in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2012, 04:10 AM
