Results 1 to 3 of 3
Thread: How to add more points or splines
    Lox
    Lox is offline
    April 4, 2013
    Christchurch, New Zealand
    157
    11:39 AM
    Hi all,
    I have created this form using only 3 splines (see pic) but now I wish I had used more (like 5 or 6) so I could further massage the shape plus it would also mean that when I add an adoptive component it would hug the surface more accurately.
    Any suggestions?
    Lox
    Attached Thumbnails Attached Thumbnails How to add more points or splines-capture.jpg
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    234
    12:39 AM
    Select the Form, you will see an X-ray button in the ribbon, next to an Add Profile button.
    Use that and you will get extra options, where you can go Add Profile and then move your mouse where you need the extra profile. Use the Xray to better understand how Revit sees your form.
    Lox
    Lox is offline
    April 4, 2013
    157
    11:39 AM
    Awesome, thanks!
  1. Can not create form from splines ?!
    Last Post: March 4th, 2017, 01:04 PM
  2. Revit and imported 3d splines.... :(
    By edsondc in forum Architecture and General Revit Questions
    Last Post: October 25th, 2015, 07:11 PM
  3. Error lofting splines through points
    By matttt in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 31st, 2014, 11:53 AM
  4. Dimensioning splines
    Last Post: January 30th, 2014, 03:34 PM
  5. workaround with splines
    By barry in forum Architecture and General Revit Questions
    Last Post: June 10th, 2011, 02:26 PM
