Results 1 to 3 of 3
Thread: Uneven surface when pattern family is applied and how to create openings in surfaces
    Lox
    Lox is offline
    April 4, 2013
    Christchurch, New Zealand
    157
    10:34 PM
    Hi all,
    I have created a cone like form made up of "timber bricks" (made from a 1/2 step surface with a Generic Model Pattern Base family) Its all looking how I would like it to except from the steps and mystery floating bricks in parts of the surface (see Pic 1). Can anyone tell me why this is occurring?
    Also I want to create openings in the "timber bricks" like the crudely marked-up image (Pic 2), is this possible?
    Thanks all
    Lox
    Attached Thumbnails Attached Thumbnails Uneven surface when pattern family is applied and how to create openings in surfaces-pic-1-uneven-surface.jpg   Uneven surface when pattern family is applied and how to create openings in surfaces-pic-2-surface-opening.jpg
    Gold Coast
    2,282
    07:34 PM
    Hard to tell without seeing your families.
    You should be able to tab select individual components and swap them out for empties
    Lox
    Lox is offline
    April 4, 2013
    157
    10:34 PM
    Thanks Elton,
    I hadn't thought of that, I found you can also tab select a individual component and delete it - but that seemed rather destructive.
  1. Surface Pattern or Pattern Component Family for Ceiliing Linework
    By nednarb in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 31st, 2015, 10:02 PM
  2. To delete part of surface but keep the same pattern and divide surface
    By leeway180 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 20th, 2015, 12:37 AM
  3. Problem with Pattern in using divided surfaces
    By mangofio in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 8th, 2013, 12:08 PM
  4. How would you create Pattern Based Family for this ?
    By Ye Zaw Lin in forum Architecture and General Revit Questions
    Last Post: December 7th, 2012, 07:58 AM
  5. Family Surface Pattern Thickness
    By W.Neuok in forum MEP - General
    Last Post: June 1st, 2011, 08:02 PM
