Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By jh75
Thread: Slab Step symbol using Adaptive Comp
    March 21, 2011
    Brisbane
    258
    03:29 PM
    I am trying to create an adaptive component that can calculate the height difference btw 2 slabs.
    As you can’t add a label to the adaptive components how would the best way be to display the value? I realise I can tag the component in the project but that is a step I would like to avoid.
    Thanks
    JH75
    Attached Thumbnails Attached Thumbnails Slab Step symbol using Adaptive Comp-step.jpg
    Attached Files Attached Files
    Bnix likes this.
    June 29, 2015
    80
    05:29 AM
    Why not using Spot Elevations to show the levels on both ends of the slabs? I like your idea of creating a symbol capable of reading two different levels, but spot elevations might do the trick although it will be more work: add two custom spot elevations (showing just the elevation text), and add the symbol separately.
    Gold Coast
    2,116
    03:29 PM
    Quote Originally Posted by jh75 View Post
    Thanks
    JH75
    I made one a few years ago, worked great until i had tons of the little suckers slowing my project down. Now i just use a type based annotation/DC which updates all at once by typing in a few numbers...
    Slab setdowns usually dont change much.
  1. Replies: 0
    Last Post: August 1st, 2014, 03:15 PM
  2. Replies: 0
    Last Post: June 20th, 2014, 12:15 PM
  3. step by step rendering relating to materials and color selection (revit 13)
    By Tom Dolle in forum Architecture and General Revit Questions
    Last Post: June 28th, 2013, 03:15 PM
  4. Adaptive Comp family missing??
    By Drew in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 23rd, 2011, 10:20 PM
  5. Spot Elevation to Step/level dif symbol
    By redmonki in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 04:20 PM
