Donate Now Goal amount for this year: 3000 USD, Received: 2477 USD (83%)
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By DanielHurtubise
  • 1 Post By aristide
Thread: Adaptive component react to a line instead a point
    October 22, 2015
    7
    05:14 PM
    Question Adaptive component react to a line instead a point
    Hi guys,
    Can the component react like below without using dynamo or grasshopper?
    The below one is mine. but it only react in one-direction.
    Many Thanks!
    Attached Thumbnails Attached Thumbnails Adaptive component react to a line instead a point-72eb5064ff6eb2cbf308bd4bee910680.png   Adaptive component react to a line instead a point-capture.jpg
    February 2, 2011
    Montreal/Paris
    802
    04:14 AM
    You will need Dynamo to do that, as far as i know.
    lum0813 likes this.
    Member aristide's Avatar
    July 11, 2011
    Boston, MA
    70
    05:14 AM
    You can certainly do something close, with a 5pt adaptive component.
    The first point is hosted to a Divided Path, with a Reporting Parameter measuring the distance to the second point.
    Where this falls short is that the Component will only react to the distance of that one particular point on that divided path, NOT the closest part of the curved line as your example shows.
    Dynamo would get you there with some of the nodes like XYZ Distance and List Minimum.
    There's probably an exact example of what you're looking for out there.
    lum0813 likes this.
    October 22, 2015
    7
    05:14 PM
    thanks for answering! any dynamo tutorial/ example do this?
  1. Adaptive Component - Materiality HELP PLEASE
    By sergiomiguel2 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 10th, 2016, 12:19 PM
  2. BIM object in adaptive component?
    By ethank in forum Architecture and General Revit Questions
    Last Post: December 18th, 2014, 12:50 PM
  3. About Adaptive Component
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 10th, 2014, 04:17 AM
  4. Replies: 0
    Last Post: May 21st, 2013, 08:45 AM
  5. Adaptive Component Help
    By djnelson75 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 3rd, 2011, 07:23 PM
