Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Hilife
Thread: Cut adaptive component in Project
    October 30, 2012
    95
    03:31 PM
    I pretty sure this can't but i need to verify this with the experts.
    I am trying to create a wood slat ceiling and I want to use another family to cut the wood slat (Adaptive Component) in the project environment.
    1. I divided a surface and placed a 2 point adaptive component and repeated. (long rectangular pieces)
    2. Then I loaded a solid family to use so to cut the repeater (solid Sphere)
    3. I use the cut tool and it looks perfect!!!
    4. ...until I click on Finish Mass.
    the wood slats go back to the original shape (rectangular).
    is there a have 2 separate families cut one another?
    thank you!
    Hany
    Attached Thumbnails Attached Thumbnails Cut adaptive component in Project-capture1.jpg   Cut adaptive component in Project-capture2.jpg
    July 20, 2011
    807
    01:31 PM
    i have no problem to use solid to cut AC or pattern based stuff, perhaps you can upload file.
    but i do have trouble to use void (instead of solid) to cut AC or pattern based stuff, anyone has clue or logic behind it?
    October 30, 2012
    95
    03:31 PM
    Hi Ning,
    I appreciate you taking the time to look at this.
    If you edit-in-place, then you see the elements cut. but once you finish editing then it goes back to it's original shape.
    thanks again,
    Attached Files Attached Files
    July 20, 2011
    807
    01:31 PM
    interesting, anyone knows what's going on?
    July 20, 2011
    807
    01:31 PM
    we have a project which will coordinate w/ pre-fab company to do fancy interior stuff, pre-fab will use Rhino to model all needed GRG stuff, we'll do overall interior layout especially the portion closely related to pre-fab GRG, in Revit.
    we're thinking using new Revit 2017 API feature to convert Rhino into native Revit stuff (DirectShape) and doing other stuff using either traditional Revit modeling functions and/or Revit AC / Pattern based features, if using AC / Pattern based then cutting AC / Pattern based will be big issue.
    anyone have experience w/ this kind of project to share i.e. process, best practice, etc.?
    Attached Thumbnails Attached Thumbnails Cut adaptive component in Project-.png
    October 30, 2012
    95
    03:31 PM
    I got it to work.
    three things to point out.
    1. The solid sphere can not be in the same family as the slat.
    2. The order of cutting is important. First select the element that needs to be cut.
    3. The element that is cutting needs to be a mass in order to hide.
    Attached Thumbnails Attached Thumbnails Cut adaptive component in Project-capture.jpg
    Dave Jones and elton williams like this.
  1. Join Lofted forms in adaptive component family project
    By taha in forum Third party Add-Ins, API and R&D
    Last Post: October 10th, 2015, 11:53 AM
  2. About Adaptive Component
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 10th, 2014, 04:17 AM
  3. Turning off divids surface of Adaptive Component in Project environment
    By Parametric Snowman in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: August 18th, 2012, 08:56 PM
  4. Replies: 0
    Last Post: September 28th, 2011, 07:11 AM
  5. Adaptive Component Help
    By djnelson75 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 3rd, 2011, 07:23 PM
