Results 1 to 9 of 9
Thread: Acoustic Triangular Panel Family
    December 20, 2010
    1,071
    12:20 PM
    I'm struggling with what I think should be a fairly simple family to create. How would you approach making this wall treatment. I was hoping to create something that I could control the projection and the triangle shapes would remain solid. Acoustic Triangular Panel Family-panels.png
    December 20, 2010
    1,071
    12:20 PM
    I made something that works, but its not as elegant as I would hope it could be.
    Attached Files Attached Files
    Member aristide's Avatar
    July 11, 2011
    Boston, MA
    74
    11:20 AM
    Solid mass looks good for figuring out your design intent.. but how do you build it? Probably triangular panels with "variable" furring, on a normal wall?
    December 20, 2010
    1,071
    12:20 PM
    They would either be just built out of framing and gypsum board then painted. or they would be fabric wrapped acoustic panels. I don't know the final design intent yet. Once I do I'll get with some of our design assist partners and figure out how to build it.Acoustic Triangular Panel Family-panels2.png Heres what they look like in place.
    Member byk3bep's Avatar
    January 30, 2014
    450
    06:20 PM
    Here is my take on it:
    2 GMA panel types, 4 and 5 point adaptive with just the height parameter (instance in my case)
    1 mass family for wall face, a couple of r.p.'s for grid intersections (add parameters if needed)
    you can take it form there
    December 20, 2010
    1,071
    12:20 PM
    Byk3bep, Your panel looks good on the outside but it is just surfaces, not solids. I wanted to make the forms as solids which is what makes it more difficult. Is there some way to make a solid "pyramid" to a point? I did it using 4 solid triangles. Should be a way, I just couldn't figure it out.
    Senior Member
    August 19, 2011
    New Hampshire
    505
    12:20 PM
    It probably isn't exactly what you need, but...
    Attached Thumbnails Attached Thumbnails Acoustic Triangular Panel Family-conceptual-mass_gcproducts_diamond-pattern_closeup.jpg
    January 30, 2014
    450
    06:20 PM
    Here is the solid version
    Not sure how you plan to use it later so it is as simple as it gets.
    Hope it helps
    December 20, 2010
    1,071
    12:20 PM
    Ahh, so you had to void out the triangle pieces. Good work, thanks.
  1. Acoustic cloud ceiling
    By jasminhusam in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 23rd, 2015, 03:56 AM
  2. Real Acoustic Ceiling
    By The Dropper in forum Architecture and General Revit Questions
    Last Post: June 9th, 2015, 04:36 PM
  3. help with Curtain Panel with Triangular Filleted Hole
    By radug in forum Architecture and General Revit Questions
    Last Post: March 27th, 2014, 08:08 PM
  4. Filleted Triangular Panel - why so complicated?
    By funkys in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 30th, 2012, 03:17 PM
  5. How do you make acoustic analysis
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: November 13th, 2011, 06:35 PM
