Results 1 to 3 of 3
Thread: Is any better way to adjust divided surface?
    Junior Member leeway180's Avatar
    January 23, 2015
    Tokyo, Japan
    36
    02:03 PM
    I did a Rhomboid divided surface and I have to move down my cross point from red point to blue point 2183mm. However, I adjusted offset and justification from property forever, but it never match what I want to.
    Does anyone have a better way to adjust divided surface pattern?
    Please refer the attaching JPEG.
    Sincerely,
    Li-wei
    Attached Thumbnails Attached Thumbnails Is any better way to adjust divided surface?-0226-divided-surface-question.jpg
    Member Andrew P's Avatar
    February 19, 2011
    364
    05:03 AM
    try using a square pattern and rotate it 45 dergees. Then move it down to the point you want. See if that works.
    January 23, 2015
    Tokyo, Japan
    36
    02:03 PM
    Thanks I will try it!!
  1. Please Help! Divided surface grid is NOT ALIGNED!!!
    By margi85 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 4th, 2014, 10:56 PM
  2. Mass without Sub-divided Surface
    By ZoLaDo in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 27th, 2013, 10:09 PM
  3. Can't get mullions on a divided surface?
    By genismk11 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 19th, 2013, 12:11 AM
  4. Divided surface gridlines constraints.
    By Darryl_S in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 20th, 2012, 12:32 PM
  5. Divided Surface
    By feio in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2011, 10:36 AM
